  New Posts New Posts RSS Feed: Zamp connection
Topic ClosedZamp connection - Event Date: 08 Nov 2016
Retired RVT View Drop Down
Direct Link To This Post Calendar Event: Zamp connection
    Posted: 11 Aug 2016 at 9:00am
I have a 182G that is solar ready.  There are are two wires in the front that are identified as Zamp connections. Do these wires have to be attached to the battery in order to plug a Zamp solar panel into the Zamp outlet on the side?  My panel works when I connect directly to the battery but when I plug into the outlet on the side, I get a 601 error which means "not connected to battery".
patrick_dube View Drop Down
Direct Link To This Post Posted: 11 Aug 2016 at 9:15am
Yup. The two wires identified as Solar or Zamp should be connected to the battery in order for this 'port' to 'work'. They also should follow the same pattern as your pod connectors (red with red, black with black).
Patrick Dubé,
2017 RP-179 owner
towed by a 2015 Cadillac SRX Premium
Direct Link To This Post Posted: 11 Aug 2016 at 9:34am
+1
Direct Link To This Post Posted: 11 Aug 2016 at 9:53am
Thanks - that corrected my problem
burnerjohnmichael View Drop Down
Direct Link To This Post Posted: 21 Aug 2016 at 7:09pm
Oh, and before you connect your solar panel controller, ring out the wires to make sure they are correctly connected to the zamp plug. My digital plug-in checker didn't register after I hooked up to the batteries. Luckily, the 1st time I used my solar panels, I hooked up directly to the batteries, so no damage to controller.
FR said they were wired incorrectly and can be fixed under warranty.  ....or, you can just reverse those two wires and solve the problem yourself.
Direct Link To This Post Posted: 21 Aug 2016 at 8:00pm
And add a fuse at the battery.
