Post Reply
| Author | |
jim park
Joined: 04 Apr 2011 Location: brownsville tx Online Status: Offline Posts: 40 |
Topic: two 6 volt batteries?Posted: 12 Apr 2011 at 9:05pm |
i bought a 2011 r-177 a few weeks ago from a forum member in california,i was shocked when he told me it had 2 six volt batteries instead of 1 12volt. he said it was an upgrade at the dealership?ive not read anything about that.has anone else got them? ps i have yet to take off the covers and look
Posted: 12 Apr 2011 at 9:47pm |
Some people "upgrade" to two 6 volt golf cart batteries, hooked up in series to make a 12 volt battery. They tend to be very heavy-duty so they should last a long time if you take care of them. Make sure you keep the water topped off, charge them at least once a month over the summer and at least once over the winter if you store it outside. If it is inside where it is warm you need to keep charging it every month. Check out this battery FAQ: http://www.windsun.com/Batteries/Battery_FAQ.htm When you do pull the cover off look for the amp hour rating on one of the batteries. Since they are in series - increasing the voltage - the amp rating of just one battery is what your battery has available (when you parallel batteries you increase the amps while keeping the voltage the same, exactly opposite of your setup). Be sure to only use half of those amps most of the time to preserve the life of the battery, but you can occasionally go up to 80%. Never go above 80%. |
Outbound
Joined: 19 Nov 2009 Location: Oshawa, Ontario Online Status: Offline Posts: 767 |
Posted: 12 Apr 2011 at 11:22pm |
Jim, I recommend that you clearly label the cables and the connections (plus take a picture or make a drawing) before you disconnect them for the winter. It'll make things easier when it comes time to reinstall them in the spring.
By the way, dual 6 volt batteries are definitely the way to go. You've got a nice setup there.
Post Reply
