  New Posts New Posts RSS Feed: Parasitic battery drains
Topic ClosedParasitic battery drains
Pod People View Drop Down
Direct Link To This Post Topic: Parasitic battery drains
    Posted: 23 Oct 2016 at 11:27am
Vann & Laura 2015 RPod 179
Direct Link To This Post Posted: 23 Oct 2016 at 11:35am
Somehow,the blank post happened- sorry!!
We just purchased 2 new 6 volt golf cart batteries. After installing them, we drove for about an hour with the truck charging them. After using them for 1 day, the meter showed they were down to 12.2 volts. We used no lights(all solar powered lanterns), the furnace came on twice and the refrigerator was on propane. The only parasitic loads that I know of was the propane detector. We have no entertainment system. I do have a 400 watt inverter directly connected to the battery, but it was not in use. We did not use the water pump. We have a 20 watt PWM solar controller installed but we did not use it.
Does anybody have an idea why the batteries were weakened so quickly?
Thanks
Vann
Direct Link To This Post Posted: 23 Oct 2016 at 12:23pm
What was their charge state to begin with? "Charged while driving" doesn't help us much.. You could have a 200aH "needed charge" and in an hour your eX can only send 30 or so back there through the Bargman connector, and if running the fridge on 12v, it ate at least 10 of them..
I have tested our standby loads, and show 165mA, and we have a couple remote control additions that sit and listen for commands.. Your best bet would be to use a multimeter to see what your steady state draws are. It easy. Just disconnect a battery cable, pos or neg will work, set your DMM to mA/A, or whatever setting it has for current that is appropriate, make sure you are plugged into the leads that match the expected current (I always use the 10A range/inputs) Then put your DMM in-line with the battery and cable, as a "jumper". You can do this with everything turned off, to see what draws you have all the time, and with some stuff turned on to see how much it draws.. but be careful with that, you don't want to blow the fuse or worse, in your DMM.
JandL View Drop Down
Direct Link To This Post Posted: 23 Oct 2016 at 3:10pm
I agree with furpod you have over 200 amp hours batteries and they may have not been fully charged when it was installed in your trailer. I would plug the trailer into AC and let onboard battery charger bring them to a fully charged state. If you have a volt meter you can check the voltage level
JandL
2013 Honda Ridgeline
2012 177
2 Paynes in a Pod
CharlieM View Drop Down
Direct Link To This Post Posted: 23 Oct 2016 at 4:02pm
Make sure the fridge is on propane, not battery, while driving. The 12V option almost guarantees little or no charging. The inverter can have a small residual draw even when not in use. Disconnect it or make sure it is truly off when not in use. Leave shore power connected for a full day between trips for a full charge. 200+ AH dual golfers should last days for usage as you describe.
mtbmitch View Drop Down
Direct Link To This Post Posted: 27 Oct 2016 at 11:08am
Also check where the battery cable ground attachment to the frame is. Mine had a coat of paint between ground cable and the frame. Only way and return voltage was getting back to the battery was via a few threads on the bolt. FR really needs to get a good qc program going.
enjoy the fresh air
Direct Link To This Post Posted: 27 Oct 2016 at 12:58pm
Originally posted by mtbmitch
......................... FR really needs to get a good qc program going.
"RV industry" and "QC" have no discernible association.
Direct Link To This Post Posted: 28 Oct 2016 at 8:57pm
lol
Luv2Q View Drop Down
Direct Link To This Post Posted: 29 Oct 2016 at 3:10am
In fact, it almost seems like they're mutually exclusive.
John & Teri
Tundra 5.7L V8 / RP 180
mjlrpod View Drop Down
Direct Link To This Post Posted: 29 Oct 2016 at 9:27am
Ive seen a few posts about batteries. Most times they say they use 2 six volt batteries. why?? is 2 sixes better than 1 twelve? is 2 twelves ok?  just wondering how i want to set mine up when i get it.
2017.5 Rp-172
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
