Page <12 |
Calendar Event: Hot water tankPosted: 16 Jun 2017 at 7:55pm |
Hey WillyBob,
If not on a 110 power source the heater can be propane heated, that's the switch not in your converter. If on 110 the CBs you need are the one in the converter and the one inside the water heater compartment. Just make sure you have water in the heater. If the fresh water tank is full, use the water pump, otherwise put city water on. |
Posted: 16 Jun 2017 at 7:59pm |
Yes, as long as you have confirmed the bypass valve doesn't bypass the water heater, make sense?
Posted: 16 Jun 2017 at 8:01pm |
That works. You can also open the cover outside and use the lever on the pressure relief valve to vent any air and make sure it is full. If you do this, it should be before you turn the heat source on so you don't scald yourself. We all were new at this once. You will learn as you go. The more you use things, the more comfortable you will be doing so. |
WillyBob
Joined: 20 Mar 2017 Location: Bend, OR Online Status: Offline Posts: 27 |
Posted: 21 Jun 2017 at 9:55am |
What do you mean by CBs? One in the converter and one in the water heater?
JivinWilly
Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3422 |
Posted: 21 Jun 2017 at 8:37pm |
CB=circuit breaker
WillyBob
Posted: 21 Jun 2017 at 11:15pm |
About this site...how does one post a new question to the forum? I can't find anything like "post a topic" or "post a new?". I only see how to post a reply, so how to start another discussion. I have many questions about our rpod.
JivinWilly
fwunder
Posted: 21 Jun 2017 at 11:27pm |
Edited to add: Pick a forum (there are many like Podmods, Maintenance, Tips and Tricks) and then: ![]() |
Page <12 |
