  New Posts New Posts RSS Feed: DVD not working
Topic ClosedDVD not working - Event Date: 06 Feb 2017
Madmojo View Drop Down
Direct Link To This Post Calendar Event: DVD not working
    Posted: 02 Jun 2017 at 8:23pm
We tried to use the dvd player in our 2017 176 and it kept spitting the dvd back out.  ANyone else have an issue?
Direct Link To This Post Posted: 03 Jun 2017 at 8:31am
Never had the issue in Pod. But have had issues with drives in past. Does it attempt to spin (read) then eject or just eject no spin. You could try a discwasher disc the unit may be dirty or have an obstruction. Sounds like it is new, did it ever work?
Direct Link To This Post Posted: 03 Jun 2017 at 2:54pm
Was it a blue ray? Can't read those and will spit them out.
Direct Link To This Post Posted: 04 Jun 2017 at 8:18am
It is brand new r pod.  When you put in the disk it does not sound like it is spinning after a few seconds it ejects the disc.  I have read that there is a transport screw in the back that needs to be removed. It should of been removed during installation.
Just a dvd not a blueray
Direct Link To This Post Posted: 04 Jun 2017 at 11:57am
check the screw then.. only 4 screws hold the unit in the wall..
Direct Link To This Post Posted: 04 Jun 2017 at 4:10pm
Still not clear - did it ever work?
ozon8r View Drop Down
Direct Link To This Post Posted: 14 Jun 2017 at 8:46am
I had the same issue. Removed the unit from the wall (four screws). Then removed the screw on top that says something like "remove screw before installing". Solved my issue of spitting out the disc.
Direct Link To This Post Posted: 14 Jun 2017 at 9:09am
Sounds like Jimmie on the production line was taking a lunch break?  Wacko
GLBCamper View Drop Down
Direct Link To This Post Posted: 14 Jun 2017 at 9:26am
+1.  Remove the faceplate. You'll see the sticker that says to remove this screw. Works perfectly. Easy peasy.
Old: 2014 177 HRE
2015 Tacoma V6 4x4 Double Cab
New: 2016 EVO ATS 200rd
2016 F150 4x4 Sport
Direct Link To This Post Posted: 14 Jun 2017 at 7:54pm
I took out the unit from the wall and there was the RED sticker to remove the transport screw before installation.  I removed the screw and now it works.  It looks like many have had the same problem.  If only the factory workers could follow instructions.Confused
