  New Posts New Posts RSS Feed: Picacho Peak State Park
Topic ClosedPicacho Peak State Park
kylekai View Drop Down
Direct Link To This Post Topic: Picacho Peak State Park
    Posted: 04 Apr 2017 at 10:14pm
Stayed at Picacho Peak State Park in Arizona a week ago: https://azstateparks.com/picacho/
Great hikes, nice warm weather and cool at night. Electricity but no water hookups.
One day was very windy and couldn't keep the door open on our 179 -- see below.  Any thoughts on how to keep the door open on windy days?
Direct Link To This Post Posted: 05 Apr 2017 at 8:32am
I put a standard 6" T Style entry door holder on mine. Available in plastic and metal. Cheap, works fine.
Direct Link To This Post Posted: 05 Apr 2017 at 10:41am
Where would you attach the T Style door holder on a 179?  On the wheel fender? Happen to have a picture?
Direct Link To This Post Posted: 06 Apr 2017 at 9:25am
sorry kylekai, I didn't see pics when I replied. The 179 poses an issue with the fender. I have seen pics of mods where a rubber door stop was mounted that stopped the door from hitting the marker light and then bungee was used to secure door open. Does your model have the friction mechanism? I think you could still use a T latch, I would mount it as far out on fender as possible. I defer to the 179 gurus, I have a 178, so don't have a door/fender issue.
Direct Link To This Post Posted: 06 Apr 2017 at 4:23pm
We have a 2016 RP-179. When we purchased it, the fender was scraped where the door had been opened too far. It was replaced under warranty. To attempt to prevent that from happening again, I took some U channel rubber molding and used black silicone to glue it to the bottom of the door. Now, when the door is opened too far, the rubber hits the fender and not the metal of the door. I complained about this to Forest River, and saw that they had started putting a bumper on the fender. I had told them that the door may stay open, but it needs something to keep it from hitting the fender. I guess they thought it made sense.
So far, the friction of the door has held it open when I needed it to stay open. I have not tried having it open in strong winds. Even with a T latch, I don't think I would want the door open with a strong wind. With the window I installed, it is not needed for ventilation. I can open the window instead since I installed the rectangular window that can open and not the one like the new R-Pods have or the round porthole.
Direct Link To This Post Posted: 06 Apr 2017 at 6:20pm
Thanks Stephen, looking at pics I agree a T latch probably doesn't have leverage needed to hold door in strong wind. Even if you bolted it thru the door. I did notice lot of issues with door and fender on interweb, easy fix would be left hand hinges and left opening vice right hand hardware. Interesting. Thanks for weighing in.
Direct Link To This Post Posted: 06 Apr 2017 at 6:53pm
That's a nice looking site!
Direct Link To This Post Posted: 06 Apr 2017 at 7:53pm
I for one would not like a door with left-hand hinges. If, for some reason, the door were to come unlatched while going down the road, a left-hand hinge would mean the force of the wind would open the door rather than help keep it shut. Given the construction of the door, I would think a rather large backing plate would be needed to spread the force enough to keep the catch for a T latch from ripping out of the door. That would need to be in place before the outer skin was put in place. The friction hinge does work well enough. Adding the bumper to the door bottom and/or the fender is sufficient to prevent the door from hitting the fender and damaging it.
john in idaho View Drop Down
Direct Link To This Post Posted: 07 Apr 2017 at 10:14am
the bungee cord to the wheel is simple and works.  I have had those metal folding hooks on the door of my tack room on the horse trailer pull out with a gust of wind.
Direct Link To This Post Posted: 07 Apr 2017 at 10:17am
Yeah, I might just stick with the bungee cord.  It's not that windy very often.
Thanks for all the suggestions.
