  New Posts New Posts RSS Feed: Propane hose leak?
Topic ClosedPropane hose leak?
kylekai View Drop Down
Direct Link To This Post Topic: Propane hose leak?
    Posted: 01 Apr 2017 at 12:25pm
Right after I purchased my new 179 RPOD about 1.5 years ago, I purchased a larger (taller) propane tank.  Today I touched the hose (slightly bending it) leading from the tank, and I heard and smelled gas leaking from the area shown below.  Maybe it's because the hose was stretched a bit, maybe the hose is old, maybe this is normal?
I don't think a slight bend in the hose should leak propane, should it?  I suppose I should replace the hose with a longer hose?  If so, any recommendations (preferably at Amazon)?
Thanks!
Direct Link To This Post Posted: 01 Apr 2017 at 4:22pm
There is no such thing as a leak in a gas line to be normal. Mine is bend but no leaks, time for a new hose.
Direct Link To This Post Posted: 01 Apr 2017 at 5:47pm
+1, no leak is normal, that hose can be exposed to the elements. Time to replace.
Direct Link To This Post Posted: 01 Apr 2017 at 6:34pm
Definitely get a longer hose, as mentioned above, no leak is normal under any circumstances.  Good chance that the hose was stretched to allow for a connection with a taller tank.  I looked at the hose on my 177; no way could I stretch it to fit a taller tank as I only have a few inches of leeway.
Direct Link To This Post Posted: 01 Apr 2017 at 7:34pm
Thanks for the input.  I suspected the hose should not leak at all.  Looking for a replacement, I found a 2 ft hose which is what it is now, and a 5 ft hose from Amazon: http://a.co/g7uCmLM
I suppose 5 ft will do if I can't find something shorter.  Does that look like the correct hose?
Thanks!
Tars Tarkas View Drop Down
Direct Link To This Post Posted: 01 Apr 2017 at 7:40pm
Nothing against Amazon at all, but if you want to see what you're getting first hand, you can probably find hoses, etc., at Home Depot or Lowes, in the barbecue grill area.
I imagine you've already done this, but until you get this fixed you really need to turn the gas off at the tank.
Direct Link To This Post Posted: 01 Apr 2017 at 7:42pm
Good point, about Home Depot, as it's only a mile away from me.
I'm at home now, just returned from a trip, so gas is off.
Thanks.
Direct Link To This Post Posted: 01 Apr 2017 at 8:13pm
I had a hose leak, but at the other end where it attached to the regulator. It was at the equivalent joint there. It started leaking at less than a year old. Warranty replacement would have cost us more than replacing it myself by the time towing it to the dealer and back figured in.
Direct Link To This Post Posted: 02 Apr 2017 at 7:09pm
I had a leak at that same connection and replaced it with a part I ordered from Amazon.  Easy 10 minute fix, just make sure you use the yellow teflon tape on the threads.
Direct Link To This Post Posted: 02 Apr 2017 at 7:14pm
I ended up getting a hose at http://propanegear.com as they had the exact length I wanted and the price was right.
