Page <123> |
Shine126
Joined: 05 Jan 2017 Location: Maryland Online Status: Offline Posts: 2 |
Topic: Rpod LP quick disconnectPosted: 03 Feb 2017 at 5:14pm |
where could I get a fitting for the grill we have been everywhere. We have a coleman and a new 179 R Pod
cjscinta
Joined: 21 Nov 2016 Location: Franklin, TN Online Status: Offline Posts: 84 |
Posted: 14 Mar 2017 at 2:42pm |
Anybody have any info on this? Portable gas grill such as the Coleman road trip and the quick connect on the pod. This can't be that tough right? I get that it's low pressure at the quick connect and the Coleman uses a regulator and high pressure 1 pound tanks. . I'm looking for an adapter and a 6 foot hose that works with it. Do they make such a thing?
2017 R-pod 179
Posted: 14 Mar 2017 at 3:47pm |
Not that complicated. I have Weber Qs, that take a 1 lb bottle. The regulator is on the grill. If I want to use a propane tank, I add a hose that adapts to the regulator then goes directly to the tank. One end is the same size as a 1 lb bottle hook up, the other is a standard tank adapter. The regulator is in line. They sell them at Lowes's. Pod People said he uses a Y connector, one end connected to Pod regulator, one outlet available to go to grill, same deal, it goes directly to the regulator on the grill. If you have a grill or anything else, propane run, that doesn't have a regulator in line, you need a regulator. I'm looking out window at my Weber Q on the deck, the hose from the regulator to the tank, I would guess is 6' long.
Posted: 14 Mar 2017 at 4:05pm |
Suggestion - Amazon sells a 6' Adaptor Hose to connect 20lb tanks to grill regulator. Weber 6501, $24.19. It is a Weber, but both ends are standard for tank and 1lb propane bottle connector.
cjscinta
Posted: 15 Mar 2017 at 12:55am |
Thanks Mike. The quick connect that is on the pod is downstream from the regulator so I understand it is low pressure already. The gas grill has a regulator on it that has to be removed before you can hook up a hose to it. I need the correct hose and connector that will connect one end to the pod and the other end to the gas grill with the regulator removed. Am I understanding it correctly? If so what connector do I need?
2017 R-pod 179
Posted: 15 Mar 2017 at 9:13am |
Google high pressure to low pressure propane connection conversion.
Or watch this video by our very own kymooses.. Video.. |
cjscinta
Posted: 15 Mar 2017 at 9:36am |
Ahh. Perfect. Exactly what I needed. Thanks Furpod ( and Kymooses). I'm still amazed that camco or someone else doesn't sell a complete conversion kit but this will definitely work. Thanks again all.
2017 R-pod 179
Pod People
Joined: 22 Sep 2011 Location: Chapel Hill,NC Online Status: Offline Posts: 1093 |
Posted: 15 Mar 2017 at 10:12am |
one minor correction to Mccarter's post above--
we do use a "Y" connector at the propane TANK-one side goes to the pod regulator and then on to the pod gas appliances. the other side of the "Y" has a hose with a standard 20 pound tank fitting and it then goes directly to the regulator which is attached to our small portable grill . this is the end of the hose that has the same fitting that the 1 pound bottles would fit into. We found the hose at a grill store. It works well. the "Y" will supply propane only if there is a connection to it. thus, if only one side is being used by the pod and the grill side is not connected to a hose, there is no propane flowing through the empty side of the "Y". the only downsides that I forsee is the possibility to forget to turn off the grill or to disconnect the hose and it then leaks out all of your propane. Vann |
Posted: 15 Mar 2017 at 10:45am |
Forgetting to turn off the grill will use the propane. Disconnecting the hose from the grill should not empty the hose and tank as it should have a valve inside like the 1 lb bottles have to keep it from leaking. Having it connected with the grill shut off also should not cause it to leak propane if the grill's valve(s) is/are working correctly. Edit: I just remembered that you had removed the regulator and added a quick-connect. My apologies. That would leak the propane if disconnected. However, if the stove's controls are working, leaving it connected should not cause any leaks if those controls are working properly. |
Posted: 15 Mar 2017 at 11:10am |
Pod People,
So you have a Y at the tank. One side goes to the standard POD propane system and the other has a hose on it that goes to the grill. I take it that hose is not 20' or so. That is what I took from your posts. You didn't connect into the existing propane system and you didn't remove the regulator from your grill. Thanks. Mike |
Page <123> |
