  New Posts New Posts RSS Feed: Rpod LP quick disconnect
Topic ClosedRpod LP quick disconnect
Shine126 View Drop Down
Direct Link To This Post Topic: Rpod LP quick disconnect
    Posted: 03 Feb 2017 at 5:14pm
where could I get a fitting for the grill we have been everywhere.  We have a coleman and a new 179 R Pod
cjscinta View Drop Down
Direct Link To This Post Posted: 14 Mar 2017 at 2:42pm
Anybody have any info on this? Portable gas grill such as the Coleman road trip and the quick connect on the pod. This can't be that tough right? I get that it's low pressure at the quick connect and the Coleman uses a regulator and high pressure 1 pound tanks. . I'm looking for an adapter and a 6 foot hose that works with it. Do they make such a thing?
2017 R-pod 179
Direct Link To This Post Posted: 14 Mar 2017 at 3:47pm
Not that complicated. I have Weber Qs, that take a 1 lb bottle. The regulator is on the grill. If I want to use a propane tank, I add a hose that adapts to the regulator then goes directly to the tank. One end is the same size as a 1 lb bottle hook up, the other is a standard tank adapter. The regulator is in line. They sell them at Lowes's. Pod People said he uses a Y connector, one end connected to Pod regulator, one outlet available to go to grill, same deal, it goes directly to the regulator on the grill. If you have a grill or anything else, propane run, that doesn't have a regulator in line, you need a regulator. I'm looking out window at my Weber Q on the deck, the hose from the regulator to the tank, I would guess is 6' long.
Direct Link To This Post Posted: 14 Mar 2017 at 4:05pm
Suggestion - Amazon sells a 6' Adaptor Hose to connect 20lb tanks to grill regulator. Weber 6501, $24.19. It is a Weber, but both ends are standard for tank and 1lb propane bottle connector.
Direct Link To This Post Posted: 15 Mar 2017 at 12:55am
Thanks Mike. The quick connect that is on the pod is downstream from the regulator so I understand it is low pressure already. The gas grill has a regulator on it that has to be removed before you can hook up a hose to it. I need the correct hose and connector that will connect one end to the pod and the other end to the gas grill with the regulator removed. Am I understanding it correctly? If so what connector do I need?
2017 R-pod 179
Direct Link To This Post Posted: 15 Mar 2017 at 9:13am
Google high pressure to low pressure propane connection conversion.
Or watch this video by our very own kymooses..
Video..
Direct Link To This Post Posted: 15 Mar 2017 at 9:36am
Ahh. Perfect. Exactly what I needed. Thanks Furpod ( and Kymooses). I'm still amazed that camco or someone else doesn't sell a complete conversion kit but this will definitely work. Thanks again all.
2017 R-pod 179
Pod People View Drop Down
Direct Link To This Post Posted: 15 Mar 2017 at 10:12am
one minor correction to Mccarter's post above--
we do use a "Y" connector at the propane TANK-one side goes to the pod regulator and then on to the pod gas appliances.  the other side of the "Y" has a hose with a standard 20 pound tank fitting and it then goes directly to the regulator which is attached to our small portable grill . this is the end of the hose that has the same fitting that the 1 pound bottles would fit into.  We found the hose at a grill store.
It works well.  the "Y" will supply propane only if there is a connection to it.  thus, if only one side is being used by the pod and the grill side is not connected to a hose, there is no propane flowing through the empty side of the "Y".  the only downsides that I forsee is the possibility to forget to turn off the grill or to disconnect the hose and it then leaks out all of your propane.
Vann
Vann & Laura 2015 RPod 179
Direct Link To This Post Posted: 15 Mar 2017 at 10:45am
Vann
Forgetting to turn off the grill will use the propane. Disconnecting the hose from the grill should not empty the hose and tank as it should have a valve inside like the 1 lb bottles have to keep it from leaking. Having it connected with the grill shut off also should not cause it to leak propane if the grill's valve(s) is/are working correctly.
Edit:  I just remembered that you had removed the regulator and added a quick-connect. My apologies. That would leak the propane if disconnected. However, if the stove's controls are working, leaving it connected should not cause any leaks if those controls are working properly.
Direct Link To This Post Posted: 15 Mar 2017 at 11:10am
Pod People,
So you have a Y at the tank. One side goes to the standard POD propane system and the other has a hose on it that goes to the grill. I take it that hose is not 20' or so. That is what I took from your posts. You didn't connect into the existing propane system and you didn't remove the regulator from your grill.
Thanks. Mike
