Wood River Pod
Topic: Surge protector installation Posted: 04 Mar 2017 at 8:33pm |
I just installed by Progressive Industries EMS HW30C. Everything went as planned. Turned on the power and display scrolled through the readings showing no errors and the power came on. Then the display started flashing 888. Turned on the bypass and then off. Just flashed 888. Unplugged from the wall and tried again. SP fires up and scrolls through the readings, no errors, then after about 15 sec the display flashes 888. I should say that the power in the pod is on and everything seems to work. Any ideas. Sent PI an email as well. Should I keep it plugged in? Thanks
Wood River Pod
Posted: 04 Mar 2017 at 8:37pm |
I should also say that I'm plugged into a regular 120 outlet with an adapter to my 30 amp line. If that makes a difference. Thanks
Ira
Posted: 04 Mar 2017 at 8:43pm |
This is just a wild guess. However, I know it is important that the black object (current sensor) that the hot wire goes through must have the arrow pointed toward the middle of the surge protector. Is that the way you have it? Interesting error code of 888, as that is not in their error code list. Good luck. Someone on here will have the answer.
Ira
Posted: 04 Mar 2017 at 8:44pm |
That is the way I was plugged in also, and it worked. So, that should not be the cause.
Wood River Pod
Posted: 04 Mar 2017 at 10:43pm |
So more info from my first post.
The unit will scroll through volts, amps and barley gets to 60 Hz before starts flashing the 888. When I unplug from the wall, the unit starts, scrolls though v,a,h, and e-code, then after the time delay kicks on the power the it goes to the 888 just after 60 h shows up. Always at the hertz. Same happens if I switch on bypass, it'll go through v,a,h and then 888.
Have an email into PI.
Thanks Jeff
Wood River Pod
Posted: 06 Mar 2017 at 9:36am |
I called Progressive Industries this morning. They said they think it's because the outlet (120/15A) I'm plugged has other items running off it and therefore is not providing enough power to the coach/unit and the to operate correctly.
The outlet I'm plugged into runs off my garage which has a large electric heater, other mechanical, and I maybe is connected to the laundry room, so maybe washer or dryer.
They gave me a couple drills to run to see if it's not another problem. Been meaning to call my buddy/electrician to put in a 30 amp plug. Panel is just on the other side of the wall, so should be easy.
Wanted to let the group know. Thanks
Wood River Pod
Posted: 08 Mar 2017 at 10:02am |
Donald from Progressive Industries and I have been going back and forth with a few tests to try and determine the 888 issue. He said that the 888 error code could mean a bad capacitor. They are sending me out a new unit. Since were headed out on the 17th for spring break, that was the best solution. I'll have to go through the work of uninstall and reinstall, but now that all the heavy lifting is done, it should be easy. I'll send back the old one that they'll refurbish.
I was most impressed with there willingness to get us up and running before we leave town on the 17th. Donald and Progressive Industries customer service get an A in my book.
Thanks
