  New Posts New Posts RSS Feed: shower water pressure
Topic Closedshower water pressure
ilthyn View Drop Down
Direct Link To This Post Topic: shower water pressure
    Posted: 21 Feb 2017 at 5:46pm
Does anyone know why my shower only trickles out water?
I dismantled the whole assembly and blew through it, so it is not plugged (unless both hot and cold are plugged.)
Never used it for the first two years as my ex did not want mold etc. The sink and toilet pressures are just fine.
Seriously, it is just a trickle.
Thanks,
ilthyn
mjlrpod View Drop Down
Direct Link To This Post Posted: 21 Feb 2017 at 6:41pm
Shot in the  dark. Sawdust in the mixing valve?
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
Direct Link To This Post Posted: 21 Feb 2017 at 7:25pm
Great thought mjlrpod.  That would be my guess as that is the only thing between the pump and the shower outlet, as far as I know.
+1
Direct Link To This Post Posted: 21 Feb 2017 at 7:34pm
Well, I'll check it out guys but I did blow through it and there was no blockage.
Direct Link To This Post Posted: 21 Feb 2017 at 7:42pm
Try unscrewing the "wand" and turning the water on.. see if the blockage is before the hose, or after..
densmorema View Drop Down
Direct Link To This Post Posted: 22 Feb 2017 at 6:34pm
Assuming you pulled the diverter knob on the bathroom sink faucet there is a on off button on the shower head you might want to to check.
Mike and Cherie
Michigan
2015 R179 2016 silverado
jalong View Drop Down
Direct Link To This Post Posted: 22 Feb 2017 at 6:57pm
As the water heater anode rod ages it sheds small chunks that can clog up plumbing fixtures. The sink screen has clogged a few times for us.
John & Sue
2016 179 - built in April 2015
2014 Jeep Grand Cherokee 3.6L 13-16mpg with 179 - 21-28mpg without
TheBum View Drop Down
Direct Link To This Post Posted: 23 Feb 2017 at 10:59am
It's not a bad idea to drain the hot water tank occasionally. I was surprised by the amount of particulate matter that came out the anode rod hole when we drained ours to sanitize the system. I could definitely envision that causing clogs.
Direct Link To This Post Posted: 23 Feb 2017 at 2:13pm
I agree, every year as part of winterizing. You can use hose on jet spray, but they make a very inexpensive wand that attaches to water hose to flush inside of water heater.
