  <title>R-pod Owners Forum : shower water pressure</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Wish List : shower water pressure</description>
  <pubDate>Fri, 23 Oct 2026 15:05:15 +0000</pubDate>
  <lastBuildDate>Wed, 05 Apr 2017 08:28:36 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=9364</WebWizForums:feedURL>
   <title>shower water pressure : While unwinterizing our pod I...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9364&amp;PID=90525#90525</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6036" rel="nofollow">lostagain</a><br /><strong>Subject:</strong> 9364<br /><strong>Posted:</strong> 05 Apr 2017 at 8:28am<br /><br />While unwinterizing our pod I noticed that the shower valve has an anti-siphon feature (this stuff is new to us as we got our pod last fall and managed only 1 trip before the snow came to the Sierra). &nbsp;If you disconnect the shower hose at the valve you can see what kind of water flow you have there. &nbsp;Could be the valve is blocked by scale from the hot water heater. &nbsp;There is just a little hole on the top of the valve where the hose connects for the water to go through and the scale chunks I cleaned out of our tank when I put in the new anode rod could easily stop it up. &nbsp;Also, since the anti-siphon valve drains the shower hose, you could have an entomology experiment in it that has blocked the hose.]]>
   <pubDate>Wed, 05 Apr 2017 08:28:36 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9364&amp;PID=90525#90525</guid>
   <title>shower water pressure :   Originally posted by ilthynPart...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9364&amp;PID=90505#90505</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2297" rel="nofollow">fwunder</a><br /><strong>Subject:</strong> 9364<br /><strong>Posted:</strong> 04 Apr 2017 at 8:18pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by ilthyn</strong></em><br /><br /><br><div>Part of my problem is that my Ex would not allow use of the shower, so I do not remember if it was ever good.</div></td></tr></table><div><br></div><div>Yep! That would do it! The Ex thing, I mean.&nbsp;<img src="https://www.rpod-owners.com/smileys/smiley11.gif" border="0" alt="Dead" title="Dead" /></div><div><br></div><div>Bathing is a good thing ®</div><div><br></div><div>fred</div>]]>
   <pubDate>Tue, 04 Apr 2017 20:18:04 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9364&amp;PID=90505#90505</guid>
   <title>shower water pressure : Thanks, All, for the input.I have...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9364&amp;PID=90486#90486</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1914" rel="nofollow">ilthyn</a><br /><strong>Subject:</strong> 9364<br /><strong>Posted:</strong> 04 Apr 2017 at 2:40pm<br /><br />Thanks, All, for the input.<div>I have cleaned most of the filters, the one input to the pump had critters in it. The Pod is a 2011, so I guess there can &nbsp;be buildup through that time.</div><div>I will check some more once the water has become "mobile", here in Canada.<img src="https://www.rpod-owners.com/smileys/smiley1.gif" border="0" alt="Smile" title="Smile" /></div><div>Part of my problem is that my Ex would not allow use of the shower, so I do not remember if it was ever good.</div>]]>
   <pubDate>Tue, 04 Apr 2017 14:40:28 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9364&amp;PID=90486#90486</guid>
   <title>shower water pressure : Thanks to All for information....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9364&amp;PID=90485#90485</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1914" rel="nofollow">ilthyn</a><br /><strong>Subject:</strong> 9364<br /><strong>Posted:</strong> 04 Apr 2017 at 2:23pm<br /><br />Thanks to All for information. I will try and act on it once the water becomes "mobile" again, here in Canada&nbsp;<img src="https://www.rpod-owners.com/smileys/smiley1.gif" border="0" alt="Smile" title="Smile" /><img src="https://www.rpod-owners.com/smileys/smiley1.gif" border="0" alt="Smile" title="Smile" /><img src="https://www.rpod-owners.com/smileys/smiley1.gif" border="0" alt="Smile" title="Smile" /><img src="https://www.rpod-owners.com/smileys/smiley1.gif" border="0" alt="Smile" title="Smile" />&nbsp; &nbsp; I have cleaned most of the filters. Part of my assessing problem is that my Ex never allowed use of the shower, so now I have discovered the problem and don't know if it has always been there, although I am pretty sure it used to be better.<div>I will update later, certainly if I find the problem.&nbsp;</div><div>My pump intake filter &nbsp;did have some dead critters in it, so regular cleaning should be done.<br><div><br></div></div>]]>
   <pubDate>Tue, 04 Apr 2017 14:23:40 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9364&amp;PID=90485#90485</guid>
   <title>shower water pressure : Very easy, you should inspect...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9364&amp;PID=90350#90350</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5187" rel="nofollow">mcarter</a><br /><strong>Subject:</strong> 9364<br /><strong>Posted:</strong> 02 Apr 2017 at 5:23pm<br /><br />Very easy, you should inspect the condition of your anode, probably yearly.  Remove the anode.  Of course do not have water connected and some say to release pressure valve and certainly do not do with HOT water in tank.  As part of winterizing I have already opened low point drains.  Use appropriate socket.  Once removed your tank will probably have some accumulation of scale in the bottom of it.  I could actual feel it with my little finger.  You can clean it out by using a hose set on "jet" sprayed directly into the anode hole or with the small wand CAMCO sells that attaches to your hose, which is what I use.  They scale stuff will wash out and be visible on the ground.  The Kymooses video on YouTube reference "winterization" gives a visual.  If I didn't winterize I would still do the water heater inspect and clean.]]>
   <pubDate>Sun, 02 Apr 2017 17:23:42 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9364&amp;PID=90350#90350</guid>
   <title>shower water pressure : McCarter &amp; TheBum, question about...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9364&amp;PID=90335#90335</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5352" rel="nofollow">birderdiane526</a><br /><strong>Subject:</strong> 9364<br /><strong>Posted:</strong> 02 Apr 2017 at 2:50pm<br /><br />McCarter & TheBum, question about your posts on draining out the water heater from time to time. Since we chase the warmer weather as full-timers we haven't had to winterize. Do you still suggest this?  How do we do this? Thanks!]]>
   <pubDate>Sun, 02 Apr 2017 14:50:07 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9364&amp;PID=90335#90335</guid>
   <title>shower water pressure :   Originally posted by CharlieM  Originally...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9364&amp;PID=90321#90321</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1573" rel="nofollow">CharlieM</a><br /><strong>Subject:</strong> 9364<br /><strong>Posted:</strong> 02 Apr 2017 at 11:55am<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by CharlieM</strong></em><br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by RCRFish</strong></em><br /><br />easternmarine.com shipping/handling cost looks ridiculous to me. <br></td></tr></table><br><font size="3">The EasternMarine site was only for product reference. I bought mine from <a href="http://www.rvwaterfilterstore.com/Fixed.htm" target="_blank">http://www.rvwaterfilterstore.com/Fixed.htm</a>. Shipping for $6.92 to 77418 via USPS.<br><br></font></td></tr></table>]]>
   <pubDate>Sun, 02 Apr 2017 11:55:16 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9364&amp;PID=90321#90321</guid>
   <title>shower water pressure :   Originally posted by RCRFisheasternmarine.com...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9364&amp;PID=90319#90319</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1573" rel="nofollow">CharlieM</a><br /><strong>Subject:</strong> 9364<br /><strong>Posted:</strong> 02 Apr 2017 at 11:54am<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by RCRFish</strong></em><br /><br />easternmarine.com shipping/handling cost looks ridiculous to me. <br></td></tr></table><br><font size="3">The EasternMarine site was only for product reference. Try <a href="http://www.rvwaterfilterstore.com/Fixed.htm" target="_blank">http://www.rvwaterfilterstore.com/Fixed.htm</a>. Shipping for $6.92 to 77418 via USPS.<br><br></font>]]>
   <pubDate>Sun, 02 Apr 2017 11:54:31 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9364&amp;PID=90319#90319</guid>
   <title>shower water pressure : easternmarine.com shipping/handling...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9364&amp;PID=90316#90316</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6773" rel="nofollow">RCRFish</a><br /><strong>Subject:</strong> 9364<br /><strong>Posted:</strong> 02 Apr 2017 at 7:42am<br /><br />easternmarine.com shipping/handling cost looks ridiculous to me. <br>Product cost: $23.99<br>Shipping/Handling to 77418: $20.39<br>Total to doorstep: $44.38<br>(as of this date of posting)<br>]]>
   <pubDate>Sun, 02 Apr 2017 07:42:46 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9364&amp;PID=90316#90316</guid>
   <title>shower water pressure :    Originally posted by rda54We...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9364&amp;PID=90306#90306</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1573" rel="nofollow">CharlieM</a><br /><strong>Subject:</strong> 9364<br /><strong>Posted:</strong> 01 Apr 2017 at 7:50pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by rda54</strong></em><br /><br />We have the same problem. The water pressure is low at all the faucets. We put a water regulator on the in line. Do we need one with a gauge on it? &nbsp;</td></tr></table><br><font size="3">Low water pressure inside the camper is usually due to contaminants in the piping or faucets. Each faucet has a screen which becomes clogged with debris left over from manufacturing or dirt in the water supply. Remove the screens and clean them. The inlet of the pump also has a screen which is subject to the same clogging. Clean it. In some cases the debris can become lodged in the fittings or faucets themselves, particularly in the shower. Again, remove and clean. Use and inline filter to prevent sand etc. from entering your water system. <br><br>An inline pressure regulator is advisable since CG water systems can vary from very low to dangerously high. A regulator will limit high pressure to a safe 30-55 psi. Most cheap regulators also limit the flow so you don't get a satisfying shower flow at full open. See <a href="http://www.rpod-owners.com/forum_posts.asp?TID=8690&amp;title=water-pressure-regulators-and-flow-rates" target="_blank">http://www.rpod-owners.com/forum_posts.asp?TID=8690&amp;title=water-pressure-regulators-and-flow-rates for a discussion. </a><br>Consider the Fairview WR-RV55 regulator: <a href="http://www.easternmarine.com/water-pressure-regulator-brass-wr-rv55" target="_blank">http://www.easternmarine.com/water-pressure-regulator-brass-wr-rv55</a><br>It is preset and allows maximum flow as I discussed in the post. You do not need a gauge on a regulator unless it's adjustable, which you also don't need. Just soaks up money. <br></font>]]>
   <pubDate>Sat, 01 Apr 2017 19:50:48 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9364&amp;PID=90306#90306</guid>
   <title>shower water pressure : We have the same problem. The...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9364&amp;PID=90290#90290</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6304" rel="nofollow">rda54</a><br /><strong>Subject:</strong> 9364<br /><strong>Posted:</strong> 01 Apr 2017 at 3:37pm<br /><br />We have the same problem. The water pressure is low at all the faucets. We put a water regulator on the in line. Do we need one with a gauge on it? &nbsp;]]>
   <pubDate>Sat, 01 Apr 2017 15:37:02 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9364&amp;PID=90290#90290</guid>
   <title>shower water pressure :   Originally posted by ilthynDoes...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9364&amp;PID=90289#90289</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6773" rel="nofollow">RCRFish</a><br /><strong>Subject:</strong> 9364<br /><strong>Posted:</strong> 01 Apr 2017 at 3:12pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by ilthyn</strong></em><br /><br />Does anyone know why my shower only trickles out water?<div>I dismantled the whole assembly and blew through it, so it is not plugged (unless both hot and cold are plugged.)</div><div>Never used it for the first two years as my ex did not want mold etc. The sink and toilet pressures are just fine.</div><div>Seriously, it is just a trickle.</div><div>Thanks,&nbsp;</div><div>ilthyn</div></td></tr></table><br><br>Did you ever solve your problem? We have a similar issue too.<br>]]>
   <pubDate>Sat, 01 Apr 2017 15:12:07 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9364&amp;PID=90289#90289</guid>
   <title>shower water pressure : I agree, every year as part of...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9364&amp;PID=88385#88385</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5187" rel="nofollow">mcarter</a><br /><strong>Subject:</strong> 9364<br /><strong>Posted:</strong> 23 Feb 2017 at 2:13pm<br /><br />I agree, every year as part of winterizing.  You can use hose on jet spray, but they make a very inexpensive wand that attaches to water hose to flush inside of water heater.]]>
   <pubDate>Thu, 23 Feb 2017 14:13:45 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9364&amp;PID=88385#88385</guid>
   <title>shower water pressure : It&amp;#039;s not a bad idea to drain...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9364&amp;PID=88376#88376</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5021" rel="nofollow">TheBum</a><br /><strong>Subject:</strong> 9364<br /><strong>Posted:</strong> 23 Feb 2017 at 10:59am<br /><br />It's not a bad idea to drain the hot water tank occasionally. I was surprised by the amount of particulate matter that came out the anode rod hole when we drained ours to sanitize the system. I could definitely envision that causing clogs.]]>
   <pubDate>Thu, 23 Feb 2017 10:59:52 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9364&amp;PID=88376#88376</guid>
   <title>shower water pressure : As the water heater anode rod...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9364&amp;PID=88323#88323</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=3529" rel="nofollow">jalong</a><br /><strong>Subject:</strong> 9364<br /><strong>Posted:</strong> 22 Feb 2017 at 6:57pm<br /><br />As the water heater anode rod ages it sheds small chunks that can clog up plumbing fixtures. The sink screen has clogged a few times for us.]]>
   <pubDate>Wed, 22 Feb 2017 18:57:48 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9364&amp;PID=88323#88323</guid>
   <title>shower water pressure : Assuming you pulled the diverter...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9364&amp;PID=88319#88319</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5787" rel="nofollow">densmorema</a><br /><strong>Subject:</strong> 9364<br /><strong>Posted:</strong> 22 Feb 2017 at 6:34pm<br /><br />Assuming you pulled the diverter knob on the bathroom sink faucet there is a on off button on the shower head you might want to to check.]]>
   <pubDate>Wed, 22 Feb 2017 18:34:45 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9364&amp;PID=88319#88319</guid>
   <title>shower water pressure : Try unscrewing the &amp;#034;wand&amp;#034;...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9364&amp;PID=88277#88277</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=936" rel="nofollow">furpod</a><br /><strong>Subject:</strong> 9364<br /><strong>Posted:</strong> 21 Feb 2017 at 7:42pm<br /><br />Try unscrewing the "wand" and turning the water on.. see if the blockage is before the hose, or after..<br><br>]]>
   <pubDate>Tue, 21 Feb 2017 19:42:56 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9364&amp;PID=88277#88277</guid>
   <title>shower water pressure : Well, I&amp;#039;ll check it out guys...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9364&amp;PID=88275#88275</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1914" rel="nofollow">ilthyn</a><br /><strong>Subject:</strong> 9364<br /><strong>Posted:</strong> 21 Feb 2017 at 7:34pm<br /><br />Well, I'll check it out guys but I did blow through it and there was no blockage.<div><br></div>]]>
   <pubDate>Tue, 21 Feb 2017 19:34:43 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9364&amp;PID=88275#88275</guid>
   <title>shower water pressure : +1   </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9364&amp;PID=88272#88272</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1100" rel="nofollow">Leo B</a><br /><strong>Subject:</strong> 9364<br /><strong>Posted:</strong> 21 Feb 2017 at 7:25pm<br /><br />+1]]>
   <pubDate>Tue, 21 Feb 2017 19:25:51 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9364&amp;PID=88272#88272</guid>
   <title>shower water pressure : Great thought mjlrpod. That would...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9364&amp;PID=88271#88271</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1146" rel="nofollow">jato</a><br /><strong>Subject:</strong> 9364<br /><strong>Posted:</strong> 21 Feb 2017 at 7:25pm<br /><br />Great thought mjlrpod.&nbsp; That would be my guess as that is the only thing between the pump and the shower outlet, as far as I know.<br><br>]]>
   <pubDate>Tue, 21 Feb 2017 19:25:14 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9364&amp;PID=88271#88271</guid>
   <title>shower water pressure : Shot in the dark. Sawdust in the...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9364&amp;PID=88265#88265</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6126" rel="nofollow">mjlrpod</a><br /><strong>Subject:</strong> 9364<br /><strong>Posted:</strong> 21 Feb 2017 at 6:41pm<br /><br />Shot in the &nbsp;dark. Sawdust in the mixing valve?&nbsp;]]>
   <pubDate>Tue, 21 Feb 2017 18:41:25 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9364&amp;PID=88265#88265</guid>
   <title>shower water pressure : Does anyone know why my shower...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9364&amp;PID=88260#88260</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1914" rel="nofollow">ilthyn</a><br /><strong>Subject:</strong> 9364<br /><strong>Posted:</strong> 21 Feb 2017 at 5:46pm<br /><br />Does anyone know why my shower only trickles out water?<div>I dismantled the whole assembly and blew through it, so it is not plugged (unless both hot and cold are plugged.)</div><div>Never used it for the first two years as my ex did not want mold etc. The sink and toilet pressures are just fine.</div><div>Seriously, it is just a trickle.</div><div>Thanks,&nbsp;</div><div>ilthyn</div>]]>
   <pubDate>Tue, 21 Feb 2017 17:46:25 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9364&amp;PID=88260#88260</guid>
