List Your Mods: |
Page <1 1617181920 78> |
Bboudens
Joined: 30 Sep 2016 Location: Calgary AB Online Status: Offline Posts: 39 |
Topic: List Your Mods:Posted: 21 Feb 2017 at 5:52pm |
The cut off switch I haven't done yet still looking for the right size A-frame box. The switch I plan to use is a basic dead current switch. Wire it red to red and black to black and a 90 o turn cuts the connection. Used em on the rigs to kill power if you have to weld and are located as close to the batteries as possible in order to be the "first link in the chain" before another power draw. I'm gonna have my mechanic install it for me.
Keep your stick on the ice
2016 178HRE 2011 Silverado 1500 |
wolftg
Joined: 17 Jan 2017 Location: Colorado Online Status: Offline Posts: 1 |
Posted: 21 Feb 2017 at 3:48pm |
How did you wire that cutoff switch, I've tried the negative to fuse panel and it's not working...
Bboudens
Posted: 08 Feb 2017 at 12:14pm |
Wood River, I went with the peel and stick. This is more of a fashion mod than function. My spouse liked the look in some of the other trailers. I did do this mod in the fall and the sheets are still on the wall even through -20 c winter weather. Can't say if they will melt off the wall in +35 degrees. I got them at home depot. whole process took a couple hours just to be careful plus I had to remove and reinstall the window trim. Use a ruler and box cutter to keep cuts straight. My kitchen is in the slide, so I did one row of sheets along the sides about 9 in tall with long skinny tiles. Then I cut another style of small squares to use as a 3" border on the sides and as a band on the back, which ties all three walls together even tho most of the band is cut off by the window. The tiles she picked out tie in nicely with the rest of our trailer, brown and gold marble with solid dark browns beige grays and some green. Looks good. Cheers.
Wood River Pod
Joined: 30 Sep 2016 Location: Wood River, ID Online Status: Offline Posts: 153 |
Posted: 08 Feb 2017 at 11:40am |
Bboudens,
Sounds like some good work! Which brand tiles did you use? Was the peel and stick adhesive enough or did you need additional spray adhesive? Would enjoy seeing pictures of the mod. Trying to decide if I want to go with peel & stick tiles or other. Peel and stick seems lighter and easier.
Thanks for the insight. Jeff |
texman
Joined: 24 Jul 2014 Location: TeXas Online Status: Offline Posts: 446 |
Posted: 08 Feb 2017 at 9:11am |
Thanks for posting that and giving me these good ideas! definitely doing the: puck lights in storage, cupholders for water. Looking forward to the rear hitch mod. I have been contemplating that one too.
Bboudens
Posted: 07 Feb 2017 at 7:56pm |
G'day everyone. Been poking around this site for a few months now. Gathering info on "podding" learning quite a bit. Not all these Mods are done but I've been gathering the parts and once spring is here a solid weekend of work will have quite a transformation. I'll start with the outside. Exterior Mods: - two 6 volt deep cycle batteries, done last fall. To be mounted in an A frame tool box with a kill switch. - 30 lb. propane tank. plus a bbq quick connect. - 65" waste hose tube installed behind the front jacks - Removable LED "puck" touch lights installed in the storage compartments - reinforce the rear 1 1/4 hitch of the trailer to support a Yackama 4 bike rack. This I will document and do a specific post about it. Checking the drains and possibly replacing the screws that hold the fresh water tank with bolts is another mod that might happen. Interior Mods: - AC plug, USB port and volt reader mounted in the bed area. - sticker tile backsplash + towel bar and PT holder in kitchen area. - Mount a mirror on the bathroom door. - Serving tray cover for the stove top. Not planning on much cooking inside the trailer - Folding cup holders in dinette and bed area for water bottles at night. - Shelves over windows for little personal storage areas for wallets, keys and sunglasses etc. for guests. - Closet bar mounted in wet bath for towel dry area or for more storage. - stair gate in rear bed area for infant son and nephews. = giant crib. I'd like to thank everyone on the forum for all the great ideas and info. I take no credit for originality. I hope to create a mod page once it's all done. This will probably be harder for me than doing the mods. Cheers |
SuJoPodders
Joined: 02 Jun 2013 Location: Janesville Ca. Online Status: Offline Posts: 16 |
Posted: 28 Dec 2016 at 9:54pm |
Here's a link for the 2 gal accumulator tank that I used.
https://www.walmart.com/ip/2-Gallon-Accumulator-Tank-With-Wall-Mount-Bracket-1-2-Female-NPT/129564232?wmlspartner=wlpa&selectedSellerId=586&adid=22222222227040751756&wl0=&wl1=g&wl2=c&wl3=100279092994&wl4=pla-238133727634&wl5=9032722&wl6=&wl7=&wl8=&wl9=pla&wl10=112354246&wl11=online&wl12=129564232&wl13=&veh=sem
voisj
Joined: 19 Jul 2016 Location: San Luis Obispo Online Status: Offline Posts: 471 |
Posted: 28 Dec 2016 at 9:40pm |
SUJO,
Love the access Panel mod! I had been looking for a door that would fit and had no luck and thanks to you I found it!! This ones on the list!! rgds john
SuJoPodders
Posted: 27 Dec 2016 at 9:21pm |
Sorry about not including a narrative with all the photos. It's been awhile since I've posted photos here and I couldn't quite get it right.
I'm no stranger to all the steps needed to add anti-freeze to a Pod. I previously owned a 177 and had to repeat the process several times a winter since we often camp during the winter. When we bought the 179 this year I immediately located all the plumbing components. First shock, finding that none of the plywood was fastened down. Second surprise was that to reach all the valves, both pieces of plywood had to be removed. At first, I was going to just move the valves to same side of the water heater and continue to remove the bed each time. Then I figured I may as well go all in with an access door from the outside. I ordered the door from Amazon and while waiting for it to arrive I began with the process of moving the water lines. Removing the old PEX cinch clamps was the hardest task, but managed with a good pair of lever side cutters. I wanted to retain the factory appearance so I kept with the PEX piping. I only needed 5 feet each of the blue and red pipe. I did have to purchase the special crimping tool for the new cinch clamps, but you may be able to find it at a tool rental place. I needed about 25 new cinch clamps and a few elbows and tees. During this time I read a post about the benefits of an accumulator tank. The tank I used is a two gallon one. An air bladder makes up half of the tank and is pressurized at about 25 lbs. psi.The claims were that one would even out the flow and cut down on how often the water pump cycles. I found that at a setting of 25 lbs, I could run the water about fifteen seconds without the pump coming on. Not really impressive, I know. But, with the pump turned off after the system is pressurized, I found I could get a full gallon of water at full pressure before running dry. There's plenty of room on that side of the water heater to mount the tank. I made the tank the first thing in the line from the pump. I also added a valve on the line to the tank so that when it came to adding the pink stuff, I can shut it off so I don't fill the tank up with antifreeze. Once I got the door, I marked off a spot that I thought would look good, and proceeded to cut the hole. My mistake!!! My jigsaw didn't even slow down when it hit the aluminium stud! As it is the shortest stud on the wall, I wasn't too worried, but just to be safe I built a header over the opening. To avoid the stud, I would advise relocating the clearance light slightly forward. Not much. Just enough to avoid the stud. About two inches will do. Another option is to use a smaller hatch. |
Jonknite
Joined: 25 May 2015 Location: Placitas, NM Online Status: Offline Posts: 19 |
Posted: 27 Dec 2016 at 12:27pm |
kpieper876 - Are you a member of the R-Pod Owners Facebook page? A little easier to communicate. If not, my question is what size is your spare tire?
