Jazz trumpet
Topic: Electric questions Posted: 29 Jul 2016 at 11:31am |
Thanks fur pods. I'll be safe.
John and Marilyn
2016 Rpod 180
2001 Chevrolet Suburban
WillThrill
Posted: 29 Jul 2016 at 3:19pm |
+1 on the posts to the original poster. As for richtrusdale, I agree that isn't normal but not an issue with your supply. You can run the pod's A/C on a 15 amp receptacle if there is nothing else on that circuit and you don't run anything else in the pod (lights are ok). |
I tried running our Pod's AC, and nothing else, on a 15 amp circuit at our home, and nearly every time the compressor started, it flipped the breaker. When you can successfully run it or not, it's definitely borderline with only a 15 amp circuit.
2014 Hood River 177
2005 GMC Envoy XL
Posted: 30 Jul 2016 at 12:12am |
Could be a weak breaker. Also 2 different sizes of A/C have been used so yours may be larger and so on the edge especially if it is hot out.
2000 watt generator - take it to a higher altitude when it is 95 degrees out and it will loose a lot of its rated output. Plus the A/C will be harder to start because of the heat. Might work fine in your driveway at 70 F and 500 feet, but 5000 feet and 100+ (which we experienced on our current trip) and 2000 watts peak output won't cut it. This is one reason I upgraded to our current Honda which is rated 3000 watts peak.
Rustler
Posted: 30 Jul 2016 at 3:58pm |
I tried running our Pod's AC, and nothing else, on a 15 amp circuit at our home, and nearly every time the compressor started, it flipped the breaker. When you can successfully run it or not, it's definitely borderline with only a 15 amp circuit. |
My 2016 Rpod 171 has a 20 amp circuit-breaker on the air conditioner circuit. That leads one to believe there may occasionally be currents in excess of 15 amps, but less than 20 amps. So a 15 amp shore power circuit would be marginal at best. Your experience bears this out.
Russ
2009 Toyota RAV4
V6 w/ tow package
2016 Rpod 171 HRE
richtruesdale
Posted: 02 Aug 2016 at 5:21am |
Thank you everyone for your input. My fingers are crossed that I just need to provide more amps. I'm going to install a 30amp breaker and run some 10/2.
Wish me luck...if this doesn't take care of it I'll be back with more questions.
Posted: 02 Aug 2016 at 9:08am |
Nothing else on.. is a little hard to achieve.. The charger converter can draw 6-7A when it needs/wants. Most who turn everything off don't turn it off.. More then one owner has found that throwing that breaker fixes the problem..
richtruesdale
Posted: 10 Aug 2016 at 3:42pm |
well today I finished installing a 30amp service dedicated for the camper. A/C works like a champ
Posted: 10 Aug 2016 at 9:51pm |
Pics or it didn't happen.
It does make things easier when you get home from a camping trip and want to plug in quickly, or when you are ready to pre-cool the fridge and load up for a trip when it is 95 outside (so you can turn on the A/C).
richtruesdale
Posted: 14 Aug 2016 at 7:00pm |
richtruesdale
Posted: 20 Aug 2016 at 6:59pm |
