ouR escaPOD mods |
Page <1 34567 58> |
larrys39426 ![]() Newbie ![]() ![]() Joined: 30 Mar 2016 Location: Carriere, MS Online Status: Offline Posts: 17 |
![]() ![]() ![]() ![]() Posted: 08 Jun 2016 at 11:35pm |
I envy you your energy and creativity! Enjoy reading your posts, and maybe I'll be inspired to actually do some modifications -- like replacing the overly soft seat cushions and modifying the bathroom lavatory -- one of these days.
sailor323 ![]() Senior Member ![]() Joined: 11 Jun 2015 Location: S Central KY Online Status: Offline Posts: 281 |
Very nice awning! I may steal this
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6463 |
No need to steal. I posted it in the hopes that it would be useful to others. If you do use the idea, please let me know and post pictures. I have benefited from what others have done before me. I am just trying to contribute something that will be useful to others also. The awning material part is based on memories of an awning my parents had when I was young. The support system is my idea though, especially the idea of using the bottom rail and the pins I made to hold the support poles. I'll be giving it a good test this summer so I will be able to see how it works during our planned trips. Edit: My wife said that part of it is "creative recycling." Examples are turning the material of the bedspread into new curtains and using the fiber/foam from the original mattress to replace the soft foam in the cushions. ![]() |
Here is one I just completed. I wondered why Forest River left so much room behind the drawers beneath the sink in our 179. It did not seem to make sense to have so much wasted space. I decided to do something about it.
I really could not do much with the top drawer as the sink drain would interfere with making the top drawer any larger. I modified the middle and bottom drawer, adding 3 inches in depth to both of them. I disassembled them and reused the front and back of the drawer pieces. I could not find 3/8" plywood, so I got 1/2" plywood and notched it so that the total width of the drawer would remain the same. My table saw came in handy for this project as well as a pneumatic nail gun. Since I could not reuse the drawer bottoms, I used 1/4" Lauan plywood. I used carpenter's glue in addition to the nails on the corners. Since I reused the front and back, I did not have to worry about placement of the screw holes for the faceplate. For the slides, I realized that the original holes would place the mounting screws near the faceplate and in the middle of the drawer, leaving the back end unsupported. I drilled a hole in the slide parts that attach to the drawers near the back. I used some extra screws to place one in the middle where the original screws would have been. This should provide better support for the drawer and increased strength. Here's a picture of the bottom drawer. The middle drawer is the same. Both are 3" longer than the original drawers. ![]() The drawers were finished with 3 coats of Minwax semi-gloss clear polyurethane spray. They are getting their 24 hours of rest now before loading them up. |
WillG ![]() Newbie ![]() Joined: 28 May 2016 Location: Oregon Online Status: Offline Posts: 22 |
Why do you need a slide out cover? I'm a new owner and assume it is water proof.... is it to keep leaves and debris out?
R-Podder by process of elimination
2014 RP179 2011 GMC CrewCab Short Bed |
Bingo! It isn't because of leaks, but partly to keep leaves and debris off the top and partly to shade the top of the slide-out which should reduce the amount of heat gained. The same applies to the awning on the door side. It should shade the side of the R-Pod some, plus when it rains, we stay dry when we go out or come in. We've had a chance to test it as it has rained on our current trip. It works well. I did have to adjust the supports so the center is one notch above the two ends. That helps keep water from pooling on the awning.
nsl ![]() Newbie ![]() Joined: 05 Jul 2016 Location: Arizona Online Status: Offline Posts: 6 |
Good afternoon. After trying different step stools,etc. with our r-pod, I knew we needed a double step. Jayco's pod style camper comes with a double step. (Smart)
After doing some research, I found the pod forum and was really glad to see that other people wanted to double step too! I ordered one from Camping World and it should be here early next week. I do not have the capability to fabricate the metal things you did but there are 3 metal fabricators in my area. That should do the trick. Also, I use a CPAP machine too. After looking at the shelf you built above the bed (I have a model 180) is there any problem with hitting your head as you get into/out of the bed? Just wondered. ![]() Thanks for you ideas!! NSL
Some people use washers instead of the shims I made. I just wanted something more solid.
I really don't have a problem hitting my head on the shelf. It sits high enough and back far enough so that it has not been a problem. The bigger problem is crawling over my wife if she gets into bed first or if I have to get up during the night. I hope my ideas have been useful for you. |
Yeah, that is a problem. We sleep with our heads on the closet side in order to make it easier to get in and out of bed easier. |
I'll suggest that to my wife. It might work better for us also.
Page <1 34567 58> |
