| Author |    Share Topic  Topic Search  Topic Options |
  | techntrek   Admin Group - pHp
 |  Topic: Checking tire pressure Posted: 27 Jun 2016 at 9:40pm
| Originally posted by shroomer
 Another corollary of Murphy's Law, no doubt.
 If something can break, it will break just before you need to use it.
 Like the transmission dipstick tube on my truck.  Found it cracked off on Saturday after a test-tow when I went to check my fluids.  Needed it on Sunday to return some rental stage lights, had to find someone else to do it.  And will definitely need the truck starting on Friday....
 Currently in the shop. |
  | WillThrill   Senior Member
 |  Posted: 26 Jun 2016 at 11:45pm |
   It's not a bad idea either to have a small 12 volt air compressor in your vehicle along with a tire repair kit.  These repair kits are very easy to use and permanently fix the tire.  Air it up with your compressor, and you're good to go.  I also keep a can of Slime (better than Fix-a-Flat IMHO) as a backup, and then there's always the spare tire.
 2014 Hood River 177
 2005 GMC Envoy XL
  | shroomer   Senior Member
 |  Posted: 26 Jun 2016 at 5:53pm |
     Larry and Debbie w/Rosie the mutt. Old: '13 177, '06 Silverado  V6
  | Podster   Senior Member
 |  Posted: 25 Jun 2016 at 11:32pm |
   Ha Ha Ha, Truth!
     Cliff & Raelynn
Ranger 4.0/178
 |  Posted: 24 Jun 2016 at 6:19pm |
   I usually check tire pressures just before I go to make sure they're all up to snuff. Today I had a few minutes to spare and decided to check them a few days before we go. Good thing. Right tire has 18 psi. Turned out there was a screw in the tread. Now I have a couple of days to get it fixed before we go. If I had waited and checked it just before liftoff, I'd be quite unhappy.
 Lesson learned: check tires far enough in advance to get them fixed if you need to.
 Same principle applies to every other damn thing that can break as well.
