  New Posts New Posts RSS Feed: Generator
Topic ClosedGenerator
Direct Link To This Post Topic: Generator
    Posted: 10 Jun 2016 at 9:33pm
Originally posted by marwayne
I have no problem with vibration, My generator is suspended.
I've always liked your innovation for that.
Direct Link To This Post Posted: 10 Jun 2016 at 9:42pm
I would set the fan to low, which will help.  Someone else will need to step in with instructions for the digital thermostat.  1000 feet shouldn't make a noticable difference.  Not until you get up several thousand feet.  The rule of thumb is you lose 3.5% per 1000 feet, plus 1% for every 10 F above 60 F.  So go to 3000 feet at 90 F and you've lost 13.5%.
When I had my Yamaha the fan would drop in speed when the compressor started, and I do believe the overload light would briefly light.
Direct Link To This Post Posted: 10 Jun 2016 at 10:31pm
I just purchased a Supco SPP6 seres hard start capacitor, which I will install as soon as I get a chance. While I have tried the AC with the Generac iX2000 generator successfully, I think this will help with the initial surge and make it work even better.
SNO4ME View Drop Down
Direct Link To This Post Posted: 10 Jun 2016 at 10:55pm
A year ago last fall we met a gentleman out in South Dakota. He had his 3k inverter Honda mounted in an aluminum tool box in his pickup. He had it all vented out and locked up. Very quiet and very secure. Nice set up if you have a pickup.
Bruce & Donna in the Sno Pod
(and Brewer too)
2011 RP 177
borjon View Drop Down
Direct Link To This Post Posted: 14 Jun 2016 at 4:54pm
Thank you for your input. You have been very helpful. I think it might have been the heat. It was 100 degrees when we tried to run the gen. I'm not sure at this point if the general is going to be of much help when we camp in Arizona.
Direct Link To This Post Posted: 14 Jun 2016 at 6:03pm
The Supco Hard Start Capacitor is headed back. Instead of helping, it killed performance. Without, the generator would surge as the load kicked in, but settle down and run. I installed the hard start capacitor and it immediately put the generator in overload, which cuts the current feed (I guess, to protect the generator's inverter from being damaged). I removed it, and the generator can run the AC again.
I had hoped this would be an inexpensive way to make the AC work easier with the generator. I was mistaken. I guess I would have to go with Dometic's Smart Start system, but I don't want to spend over $400 to do so.
ron/roscoe View Drop Down
Direct Link To This Post Posted: 19 Jun 2016 at 4:13pm
Trying to find out the amp draw of the A/C on my 2016 Rpod 178.  My Honda 2000 puts out about 17 amps, if I turn on just the a/c, will it work?  I just don't want to smoke it!
Ron Rowland
JandL View Drop Down
Direct Link To This Post Posted: 19 Jun 2016 at 5:35pm
I have a 2012 RPod and the spec for my air conditioner are AC & fan start is 23 amps and run 16 amps
JandL
2013 Honda Ridgeline
2012 177
2 Paynes in a Pod
Direct Link To This Post Posted: 19 Jun 2016 at 9:40pm
Stephen, it should have helped, maybe you received a bad capacitor.
Direct Link To This Post Posted: 19 Jun 2016 at 9:58pm
I was careful to wire it in parallel with the capacitor like I read. I was really disappointed when it caused the generator to overload instead helping the AC to start easier. I also figured that something must have been wrong with it. That's why it went back. Since the generator will start and run the AC, I will wait and see if I need to do anything. Hopefully, I won't need to.
