  New Posts New Posts RSS Feed: Help!  Fridge not working on gas
Topic ClosedHelp! Fridge not working on gas
rvshopping View Drop Down
Direct Link To This Post Topic: Help! Fridge not working on gas
    Posted: 27 May 2016 at 1:26pm
When we try to use the fridge on gas it's beeping. It sounds like it's trying to lite. The gas stove is working fine and the propne is in. Any ideas?
Direct Link To This Post Posted: 27 May 2016 at 1:57pm
Suggestions:
1. Take the outside vent cover off and look to make sure nothing is blocking the burner area (wasp nests caused problems with ours when brand new).
2. Make sure gas lines are purged. For this, you can light the stove and make sure it burns with a steady flame.
3. Even when #2 is done, there may still be some air in the line leading to the refrigerator. It may take several tries for the remaining air to be purged and for it to light and burn steadily.
4. If it does light, observe the flame. Is it burning cleanly? Is there any flame shooting backward toward the regulator? If so, then something is blocking the flue (again, wasps are a suspect here). If it is not lighting after several attempts, then it is probably time to consult your dealer's service department to diagnose why it is not working.
Tars Tarkas View Drop Down
Direct Link To This Post Posted: 27 May 2016 at 5:41pm
I just had the same problem after putting on a new, full tank of propane.  Took me a while to figure out that I'd forgotten to open the valve on the propane bottle.  You're probably smarter than that, but I hope your solution is as simple.
Direct Link To This Post Posted: 27 May 2016 at 9:18pm
Haha I think we got it figured Out. I don't know exactly how, but after some extra random attention it started working. Maybe since we hadn't used it before there was just too much air in the lines. Thank you for your responses and ideas!
shroomer View Drop Down
Direct Link To This Post Posted: 27 May 2016 at 10:18pm
For future consideration: Open the gas valve slowly on the tank. If you open it too fast, it thinks there's a leak and it shuts off. This just happened to me when I was anxious to get everything tested. The solution was to close the valve, find something else to do for  few minutes and open it very slowly. Doug has an interesting technique he might want to reshare.
Direct Link To This Post Posted: 27 May 2016 at 11:37pm
Counting to 30 while you turn the valve?  The hot water method for determining the fuel level?  Doing the hokey-pokey while you turn yourself around?
Direct Link To This Post Posted: 28 May 2016 at 5:47am
Yeah, that last one.
Keith-N-Dar View Drop Down
Direct Link To This Post Posted: 28 May 2016 at 6:29am
What if the Hokey Pokey really is what it is all about?
2011 R-Pod 177
2010 Ford F-150
Direct Link To This Post Posted: 29 May 2016 at 9:03pm
< mind blown >
Direct Link To This Post Posted: 30 May 2016 at 6:46am
LOL
