  New Posts New Posts RSS Feed: New owners 179 with questions
Topic ClosedNew owners 179 with questions - Event Date: 20 May 2016
CharlieM View Drop Down
Direct Link To This Post Calendar Event: New owners 179 with questions
    Posted: 20 May 2016 at 10:29am
The 3.6L will struggle in mountains. Those reporting great success with the GC have the V8s. My experience with a 172 and Pilot 3.5L was it was quite adequate on level low altitudes, but the Rockies were a challenge. Pulling a parachute (trailer), climbing a grade, and altitude are three strikes against a small engine. It worked, but I was in second gear at times. The 179 is heavier than my 172 and altitude kills any engine.
Retroactive View Drop Down
Direct Link To This Post Posted: 20 May 2016 at 10:37am
Originally posted by Micky
Stephen, thank you.
Yes it has bluetooth & aux input.  It appears I would need to purchase a Sirius receiver and plug it into one of the inputs.  I know I will need an antenna but didn't want to drill any holes in the pod.  I see Sirius is now selling a wireless antenna I would prefer to go that route.
Appreciate you comments!
You could also use one of those little XM antennas that you can hang inside the window of your pod in the meantime, I used one at my house for years until Pandora came around.
Direct Link To This Post Posted: 20 May 2016 at 11:03am
I had XM with the 172 and used their home kit. It included an antenna with suction cups. It worked as well as expected. The Pod is fiberglass so doesn't attenuate signal too much. You just have to play with it.
Micky View Drop Down
Direct Link To This Post Posted: 20 May 2016 at 11:19am
Thanks Charlie, that's what we're afraid would happen if we attempted the Rockies.  We're thinking we're probable going to have to get a Ram or Ford 150.  Some people are telling us to get 250. Your thoughts?
John & Margaret
2016 Rpod 179
2013 Jeep GC
Craneman View Drop Down
Direct Link To This Post Posted: 20 May 2016 at 11:25am
[QUOTE=Micky]Thanks Charlie, that's what we're afraid would happen if we attempted the Rockies.  We're thinking we're probable going to have to get a Ram or Ford 150.  Some people are telling us to get 250. Your thoughts?[/QUOTE
  We tow with a f150 eco boost v6 turbo 365 hp 21 mph 14 towing plenty of towing power.
         Moe
Jo and Gary
2010 174
2011 Ford 150
Direct Link To This Post Posted: 20 May 2016 at 11:45am
Before upgrading I took the 172 and Pilot to the Rockies for a month, including some of the highest Colorado passes accessible by paved road. I took careful notice of how it worked, knowing I would be increasing my trailer weight by 1000#. I concluded the 3.5L was marginal, but manageable, for the 172 but more would be required for the Camplite. I upgraded to the Tacoma 4.0L and added the supercharger just to compensate for altitude. On level ground without altitude the unaided 4.0 would have been fine.
For you the Ram or F150 would be great. I'm a Ford man, but still on the fence Ecoboost vs 5.0L. Ecoboost is Ford's attempt to meet Government MPG mandates and still retain performance. The cost is more complexity and shorter engine life. In that respect the Ram may have an advantage. When towing there's no substitute for cubic inches. The F250 would be way overkill for a Pod.
Direct Link To This Post Posted: 20 May 2016 at 11:57am
Thanks everyone, really appreciating all of your input Approve
John & Margaret
2016 Rpod 179
2013 Jeep GC
Direct Link To This Post Posted: 20 May 2016 at 12:04pm
I really appreciate your information on the door window installation.  I assume you ordered the window from the same company that makes the windows in the 179? It doesn't seem difficult but neither one of us feel comfortable doing the installation ourselves Embarrassed and haven't been able to locate someone to do it.  Our dealer doesn't want to do it.
John & Margaret
2016 Rpod 179
2013 Jeep GC
Direct Link To This Post Posted: 20 May 2016 at 12:39pm
I ordered from Amazon. This link has the specific information. Door window installation.
The specific window on Amazon is this one.
I learned a long time ago that sometimes, you just have to go ahead and do some things. You will feel a sense of accomplishment when you complete it. With this, make a good template from the inside trim ring and use that as your cutting guide. Use masking tape to protect the finish. You will be amazed what you can accomplish if you don't let yourself be intimidated by the thought that you might goof it up. Yes, you might. However, if you take care, measure and cut carefully, and make sure you work carefully, you can do it.
Direct Link To This Post Posted: 20 May 2016 at 12:49pm
My Grand Caravan has the  3.6 V6 put out 283 horse.
