  New Posts New Posts RSS Feed: New 179 - Slide out question
Topic ClosedNew 179 - Slide out question
Direct Link To This Post Topic: New 179 - Slide out question
    Posted: 09 May 2016 at 9:42pm
I think that is by design. The rubber gasket compresses against the wall, sealing it (hopefully) from leaks. If you look at the EDPM material used on the top of the slide-out (no fiberglass there), you might notice it is not tight into the corner of the frame and the face. I think this might be to add some curvature that would also tend to divert any moisture outward instead of letting flow inward.
My 179 (2016, pre-stainless steel sink an flip foot) has the padded naugahide (or some other type of vinyl fabric) facing on the slide-out. I'm not sure I would like the wood better. If I hit my head on it, I'd rather it be the padded version.
Patriot Dave View Drop Down
Direct Link To This Post Posted: 09 May 2016 at 8:01pm
Originally posted by Perkx2
Just joined the group and have already learned a lot from reading the posts. We decided to sell our Trailmanor 2720 and we've had our 179 for a week. Love it so far. I'm wondering if others with a slide out can tell me if the frame around the slide out on the inside of the camper goes back flush to the wall. We have the wood trim around it. I've noticed in photos that it used to be a puffy fabric type of trim.
When opening the slide, it stops about 3/4 to 1 inch from the wall. Theres a rubber gasket all along the top that seems to stop it from fitting flush. I haven't called the dealer yet. Was just going to stop in next week when going by, but I'd thought I'd ask here. I can post a photo if my explanation is not clear enough.
Thanks.
I have a 4 week old 179 and my slide sets the same as you describe.
When we were looking at Rpods every model I was inside of, set the same way.
Dave & Joyce
Direct Link To This Post Posted: 09 May 2016 at 1:47pm
Welcome to the group!! Ditto here ours does sit out that far either
Perkx2 View Drop Down
Direct Link To This Post Posted: 09 May 2016 at 1:46pm
Thanks!
The Trailmanor was our 3rd camper. We bought a 17ft Burro in 1999. The reason we got the 2720 TM (in 2008) was mostly because I was doing craft fairs around the state and I wanted a larger camper that I could sit in at night and sew or make other stuff and my husband could have his easy chair. We liked it, never had a problem with it. It was fun. But now being retired, I just want to have a camper we can jump in, take off, with very little setup/takedown. We actually drove from Maine to Arizona and back last year and we left the TM home and took the old Burro. So, I guess the r-pod is really an upgrade from the Burro. Lots more options and space.
Ted & Mary
2016 R-Pod 179
TheBum View Drop Down
Direct Link To This Post Posted: 09 May 2016 at 1:22pm
Welcome!
The gasket could definitely be the cause. We haven't worried too much about it in our 179 and haven't had any leaks, although I don't think ours sits that far out.
Just curious: What didn't you like about the Trail Manor that made you switch over to an R-Pod? If they weren't having production issues, I was originally considering going that route.
Direct Link To This Post Posted: 09 May 2016 at 1:11pm
Thanks.
Ted & Mary
2016 R-Pod 179
