 Post Reply Post Reply Page  <1 5354555657 58>
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Topic: ouR escaPOD mods
    Posted: 20 May 2016 at 10:44pm
Who wants to go out and spend several hundred dollars for an awning? I certainly did not. After completing my slide-out cover, I thought, "Why not make an awning using the same fabric?" So I did.
The fabric is a camouflage, carbon fiber reinforced, rip-stop coated, waterproof fabric. Like the slide-out cover, I decided to use rope to fit the rail. It was, of course, a larger one than used for the slide-out.
The first thing I did was do a rough cut for length. I used a "hot knife," which in actuality was a smoothing tool for a wood burning iron. When turned on edge, it worked great for cutting the fabric, sealing it so that it will not unravel.
I folded the fabric, stitched it, and then folded it over the rope and sewed it using a zipper foot so that the seam could be as close as possible to the rope. The outside edge just got a double 1/2" fold. The two ends are the cut ends since they are sealed.
After looking online for ideas, I had decided to use PVC pipe for the supports. I changed my mind in the middle of things so I need to get some 3-way connectors in 1" size to replace the 4-way connectors which I currently have. I had originally thought to have a free-standing frame, but that ended up being too cumbersome. I now have two sections of 1" PVC pipe stretching the front of the awning with short stubs to reach the ends and make the curve to follow the gutter. For legs, I have three 1" PVC pipes with holes spaced every 6" for adjustments. These slide into 1-1/4" PVC pipes and 1/4" x 2" wire locking pins (rounded) are used to secure them in place.
The foot end of the supports got a cap, drilled to go over a pin which slides into the lower track. I still have some final fitting to do so that they will slide in smoothly over the screw heads. These were made of 1/2" round welding steel rods and 5/16" round welding steel rods. The part that slides in the track was cut to 6" and the other part was cut to 8", welded into a hole drilled in the 1/2" rod pieces, and bent to make a suitable angle for the awning when it is set up.
Now for some pictures:
To do yet: make tie-down ropes to use either with weights or stakes to help hold the outer edge. Also, re-sew one of the seams where it isn't holding properly. This is on one of the end rod pockets.
Perhaps it is time to change the name of our R-Pod to CamoPod. Big smile
Edit: I am adding a picture of the awning in use at the Whispering Winds RV park in Newark, NY recently. It shows how I add tension to the awning without stakes.
The red cans are plastic Folgers cans from a local restaurant. I made four of them. Each has a quarter-bag of ready-mix and an eye bolt with two nuts holding a fender washer. The fender washer was sunk into the wet concrete and the lid held it in place while the concrete was curing. I made ropes sufficient in length to be able to adjust the poles. I use a tautline hitch to tighten the ropes so I can easily adjust them as needed.
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2016 at 5:02pm
The top shelf in the R-Pod 179's pantry is not very well thought out. There is no shelf in it. Well, I thought to remedy that.
removed the panel that is covers the side of the pantry that is on the inside, covering the thermostat and indicator gauge wiring. I found a framework behind the panel. This was screwed into the bathroom wall and the face of the cabinet. I removed that and, after figuring out where I wanted the shelf, I added a cleat about midway on that bracket to support the end of a new shelf. I also added cleat stock around the bathroom wall, outside wall, and inside the face on the outside wall end of the cabinet. The new shelf was cut to shape to sit on top of this new supporting cleats.
I had a piece of oak stock. I used my table saw to cut a notch for the shelf and attached it to the shelf. This strengthens the front of the shelf at the opening so that it won't sag. The shelf was finished with stain and polyurethane finish, then installed.
I cut the panel which I had removed roughly in half to fit both below and above to cover the wiring again. It is good to have another shelf in the pantry.
The baskets were purchased at our local Aldi store. They were part of a set of a larger and smaller basket. The smaller ones fit the pantry perfectly. The larger ones are on the shelf above the bed and in the cupboard below the stove.
One goof I did was to purchase the "short" moly bolts at my local Lowe's store. These were too long. I needed extra short. I ended up putting a hole in the side of my R-Pod before I realized that it would do that. The second moly bolt, I was able to cut down before I tightened it down, so it did not make a second hole.
Any hints on how to repair a hole? I filled it with a dab of silicone to keep water out until I could find out how to fix it properly.
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2016 at 8:42am
This one is not for the trailer, but is quite useful.
What do you do with the hitch when you are not towing? That was the problem I had. in my 179, I was beating up the bottom of the storage area opening trying to get it in and out. the bars were not a problem. It was the shank and head. I did not want to leave the hitch attached to the car. That would not be good for it. I did not want to leave it outside, and I certainly did not want to put it in the trailer.  I decided to do something about it.
First, I was having a problem with the bottom of the shank scraping on our driveway when we pulled in or out of our driveway. The Ford Escape is low enough that the shank did not need to be so long. I used an angle grinder with a cut-off wheel to cut 2" off the bottom of the shank. Then i smoothed and painted the cut area to prevent rust. This served two purposes. The first is to eliminate the scraping of our driveway. The second was to make it possible to finish this mod.
I purchased a Ridgid 22" tool box from Home Depot. I used some scrap wood to build a cradle for the hitch. Then i put a plastic bag in and filled it with Great Stuff insulating foam. I sprayed it with some water to speed the curing. I had previously found that if I did not spray it with water that it would not cure, probably because the plastic bag kept moisture from the air out. After it expanded and cured, I had a custom-formed cushioning cradle for the hitch. There is room inside for me to keep my Hitch Grip (which I highly recommend) and the hitch locks, pins, and covers. The end result is a place where I can keep my hitch head that is clean, watertight, and which I can keep in the back of our Escape while traveling and in the R-Pod when at home. Since it is watertight, I could also keep it outside, under the R-Pod, but I would want a good cable lock if I were to do so.
Patriot Dave View Drop Down
Post Options Post Options   Quote Patriot Dave Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2016 at 11:10am
Originally posted by StephenH
I used Arrow 18 GA Brad Nails, 5/8" #BN1810 and a Black & Decker PowerShot stapler to attach the strips. I did not use glue on them.
Thanks Steven
Have a Great Day Today
Dave & Joyce
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2016 at 10:53am
Post Options Post Options   Quote Patriot Dave Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2016 at 7:49am
Okay, here's another one for those of us frustrated by the plastic track and sliders for the curtains. In our 179, it was the curtains behind the kitchen counter. After seeing that Forest River has finally addressed this in the newest R-Pods, I decided to do something about it. I purchased Cafe Curtain Rods. If you do this, make sure you get ones long enough to cover the window. They are really inexpensive at Wal-Mart.First, remove the end clip on the plastic tracks and remove the curtains.Second, remove the tracks.Third, using 1" molding, cover the screw holes. In my case, I decided to place the molding all the way across.Fourth, Attach the mounting clips for the curtains. For the center clip, I slipped one end behind the window frame and only used one screw. The others used two screws.Fifth, remove the plastic slider material from the back of the curtains. Fold and sew a casing on top and bottom. This will need to be just big enough to fit the rod.Sixth, slide the curtains onto the rods.Seventh, snap the rods into the mounting clips and adjust the curtains to cover the window evenly.Enjoy being able to move the curtains without them catching on the screw heads.Note: This made for very tight curtains. We will be making new curtains in the near future which will have a little more ease in them so they will fit better.
Did you glue the molding strip on???? If so what type of glue?
Thanks
Dave & Joyce
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2016 at 8:38pm
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2016 at 1:35pm
I'm no expert by any means. I am just not afraid to try. The faucet's original location was unacceptable. I really would like to find one that would fit even tighter into the corner, even if I have to fabricate the surrounding cover plate.
larrys39426 View Drop Down
Post Options Post Options   Quote larrys39426 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2016 at 12:54pm
Thanks -- it may come to that, but I'm likely to mess up something worse when I get tools in my hands.Embarrassed
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2016 at 10:29pm
For all of you 179 owners (and possibly other models as well) who are frustrated with the bathroom sink, this one is for you.
This modification is to move the faucet to reduce the splashing of water by making the water stream hit a wider part of the sink. Why the factory installed the faucet in the location it did is beyond me. The water stream hits right at the edge of the sink. Moving the faucet, even a small amount, allows the water stream to hit in a wider area.
Remove screws holding faucet surround and carefully use a putty knife to cut putty holding the surround to the wall. Remove it.
Disconnect faucet lines.
Remove faucet from surround.
Check the opening. Check to see if you can move the surround closer to the wall away from the door. You may be able to move it 1/4 to 1/3 of an inch while still leaving the hole covered when it is replaced.
Carefully measure just how far you can move the faucet toward the wall side, away from the door. Enlarge holes to shift faucet over, being careful not to move too far, or you will have a hole. Use some silicone sealant and reinstall faucet to the surround.
Reinstall surround, moving it as close to the wall as possible without leaving an uncovered hole in the wall. Use silicone sealant to seal around the plastic to prevent water from going behind it.
Result should be that the water from the faucet now hits more toward the drain in a wider part of the sink instead of at the edge. This will not totally eliminate water splashing, but it does reduce it.
The putty knife marks the original location of the faucet surround. The faucet was moved as far as possible also.
