Easy Camper
Joined: 06 Mar 2016 Location: Jacksonville AR Online Status: Offline Posts: 3 |
Calendar Event: 179 Water Low Point DrainPosted: 06 Mar 2016 at 8:31pm |
Hello,
I just bought a 2016 R Pod 179 and picked it up by having the dealer deliver it half way from where I live. The driver that delivered it didn't know much about it and couldn't answer many questions. It had been winterized and I was trying to get water in the system but it keeps draining out the low water drain. Where is the shutoff valve or does it just use caps on the end of the drain? If it just uses caps, I need to get the dealer to send me some because it didn't come with any. |
Easy Camper
Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3395 |
Posted: 06 Mar 2016 at 9:01pm |
As far as I know there are no shutoff valves to the fresh water tank (except the bypass to the hot water tank). The 177 we own has a cap that screws on the end of a nipple near the bottom of the water tank.
Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6477 |
Posted: 06 Mar 2016 at 9:13pm |
When I got mine, the cap for the fresh water tank drain was sitting in the hot water heater compartment. Check there. It is a convenient place. It should be a black plastic screw cap.
Joined: 14 Jan 2013 Location: Near Nashville Online Status: Offline Posts: 1456 |
Posted: 06 Mar 2016 at 10:00pm |
The low point drains just use screw-on caps. You can pick them up at Home Depot, etc. Plastic caps are probably best, but metal caps will work too. They are the same as the cap on the water tank drain, which I don't think is what you're talking about, but it's not really clear.
You might find the caps in a drawer or other storage area. TT |
FJ Cruiser |
Leo B
Joined: 13 Jan 2012 Location: Lyndonville, VT Online Status: Offline Posts: 4518 |
Posted: 07 Mar 2016 at 7:03am |
Ditto!
Easy Camper
Posted: 07 Mar 2016 at 3:14pm |
Thanks for all the comments. I looked in my hot water heater compartment and found them. How should I know there is water in my hot water heater before I turn it on? Is it safe to asume that if water comes out the hot water side of the faucet the water heater will have water and will not be damaged when turned on?
Easy Camper
Posted: 07 Mar 2016 at 4:38pm |
It is not safe to assume water at the tap means a full tank. The whole purpose of the bypass system is so you can get anti freeze at the taps without filling the HW tank. The best way to tell is to open the pressure relief valve at the top of the WH.. If you get water/pressure, you know you have water in the tank. Either the pump, or city water has to be hooked up and/or on to build pressure. |
Easy Camper
Posted: 09 Mar 2016 at 7:47pm |
That's a good idea about opening the hot water pressure relief to make sure it has water before turning on the heater. I was paranoid that I would burn up the element by not having water in the tank.
Thanks |
Easy Camper
