  New Posts New Posts RSS Feed: Reverse lights.
Topic ClosedReverse lights.
Direct Link To This Post Topic: Reverse lights.
    Posted: 16 Feb 2016 at 9:29pm
Interesting, hadn't seen that controller before.
Direct Link To This Post Posted: 16 Feb 2016 at 8:20pm
I have been very happy with the Hopkins InSIGHT Flex-Mount controller:
https://www.etrailer.com/Brake-Controller/Hopkins/HM47297.html
I like having the display on top of the dash where I can see it and the control where I can easily reach it. The Smart Box is the only part that has to be in a certain position so the inertial sensors work properly. The other two parts can mount in any location that works for the person who will use it. It is also significantly lower in price than the Tekonsha P3.
Installation was not too hard. I did not have the connections in my 2016 Escape (with factory tow package pre-wired with a 4 pin connector), so I had to run wiring from back to front for the electronic  brake controller and 12V for battery charging. I had to use the universal ETBC7 kit to install this. If your TV has the connectors built-in, you may be able to use a vehicle specific wiring kit, which would certainly be simpler. You would have the same issue even if you did go with the P3 controller.
howmanyds View Drop Down
Direct Link To This Post Posted: 16 Feb 2016 at 7:33pm
Yes, I'm most likely getting a Tekonsha P3 electronic brake controller. I found some wiring instructions at etrailer.com.
Direct Link To This Post Posted: 16 Feb 2016 at 7:16pm
Originally posted by howmanyds
I'm planning to mod my 4-pin trailer connection into a 7-pin connection before going to pick up my R-pod from the dealer. Are there reverse lights on rpods?
Thanks!
As part of that modification, you are installing a brake controller, right?
Direct Link To This Post Posted: 16 Feb 2016 at 7:01pm
The pod is wired for backup lights, all you have to do is put in backup lights and hook them up.
Direct Link To This Post Posted: 16 Feb 2016 at 6:20pm
7 pin wiring is standard thru out the industry.. if there are back up lights, there is no other configuration.
Direct Link To This Post Posted: 16 Feb 2016 at 5:52pm
Thanks. So, are R-pods configured to use that 7th pin with some other auxiliary function?
CharlieM View Drop Down
Direct Link To This Post Posted: 16 Feb 2016 at 5:48pm
No reverse lights. Only running, brake, and turn.
Direct Link To This Post Posted: 16 Feb 2016 at 4:57pm
Thanks!
