  New Posts New Posts RSS Feed: Rpod 172 Delamination Issue
Topic ClosedRpod 172 Delamination Issue
Pete Brayton View Drop Down
Direct Link To This Post Topic: Rpod 172 Delamination Issue
    Posted: 18 Sep 2015 at 1:48pm
I recently purchased a 2010 172 and I noticed an area of delamination just below the keder for the dome.  Any suggestions on how to fix it? Thanks in advance for any help.
Direct Link To This Post Posted: 19 Sep 2015 at 8:37pm
I don't think there is a solution for delamination once it has occurred.  You should strip and re-caulk that area to ensure no more water gets in.  Then I would run the A/C for a week to pull humidity out of the wall.
Direct Link To This Post Posted: 21 Sep 2015 at 1:32pm
Thanks for the reply, I figured if anyone would know what to do you would! I don't think I have a water issue as there are no signs or sounds of water inside or out and we've had no rain and pretty low humidity lately...8% yesterday.  I was wondering if it would be a good idea to try and squirt some epoxy or something in the delaminated area and try to spread it around from the outside and then re-caulk the area. Any thoughts?
Direct Link To This Post Posted: 21 Sep 2015 at 9:39pm
Not sure - anyone?  A few searches online give 2 options from what I could find - try to epoxy it like you said, or cut out the fiberglass, clean up the area behind it, and then re-fiberglass.
