POACHER
Topic: NEW 178 R-POD Posted: 21 Jun 2015 at 6:56pm |
HI EVERYONE JUST ORDERED MY 178 R-POD WE WILL PICK IT UP THE FIRST WEEK IN SEPTEMBER IF ANYONE HAS ANY SUGGESTIONS PLEASE LET ME KNOW
BLACKSMITH
Band Leader
Posted: 21 Jun 2015 at 7:39pm |
You will need wheel chocks and I had a 2 x 8 x 6ft board cut into 6 one foot pieces to stack under the tongue jack and for possible leveling. You will need a little level to put in the fridge to make it work well. Ask the dealer to show you where the manual override is for the slide in the unlikely case you need to use it. My gray water and black water tanks were labeled backwards when I picked my 178 up this spring. You might consider a voltage regulator that goes between your cord and the campground electricity socket. Campground voltage is apparently not always stable. Be careful that the bedding doesn't get caught in the slide. I almost caused a problem by not making sure it was out of the way. This may be old stuff to you, but it's just some things I did and ran into this spring. We love our RP178.
2016 R Pod 178
2001 Ford F 150 Triton V8
Kayaks and old folks bicycles
Leo B
Posted: 21 Jun 2015 at 9:06pm |
Congrats!!! Welcome to the group!!! My advise would be to make sure you get a very thorough walk thru and test everything be fore you leave the lot. Try the water systems, fridge on gas battery and electric, try the tv, radio, stove heater, a/c. microwave and anything else you can think of.
Previously owner
POACHER
Posted: 22 Jun 2015 at 6:16am |
THANKS FOR THE HELP!!!!!!!!!!
BLACKSMITH
Posted: 22 Jun 2015 at 5:57pm |
Welcome.
oldwolf
Posted: 28 Jun 2015 at 12:26pm |
When going through the initial walk-through take video with your phone or a little action cam or anything. Make sure the batteries are charged and your memory card is in or you have enough memory to record about 2 hours worth.
I forgot to check on the memory card on the action cam and my phone was low on memory so I never got video of our walk through. Now, we're just calling the dealer, reading posts and watching videos because of my mistake hehe.
Leo B
Posted: 28 Jun 2015 at 1:25pm |
Oldwolf, welcome to the group!
Previously owner
Posted: 28 Jun 2015 at 7:49pm |
Welcome. We'll get you through the learning process. Ask away!
oldwolf
Posted: 28 Jun 2015 at 11:03pm |
Thanks all. :)
johnremmett
Posted: 02 Jul 2015 at 10:08am |
Check your sink drain connection. Due to the slide a flexible drain line is used. Turns out mine was barely attached from the factory and would leak every time water went down the drain.
My other recommendation is that you buy a mattress topper which will make the bed really comfortable. A couple of small rugs for the floor. A man-made chamois cloth to wipe down the shower after use is advisable.
I also purchased a weight-distributing hitch but don't use it now. I do have a sway control and always use it.
