68LC
Topic: Lessons Learned Posted: 08 Mar 2015 at 7:31pm |
Just a few field notes: 1. Be sure to taste the "city water" before you just hook up to it. It could be too mineralized or just plain nasty tasting. Ask me how I know this. Draining system now. 2. When setting up, if you plan to use the garage feature and want some shade, put that end of the trailer facing north. Again, ask me how I know this. 3. That little Aussie grill that came with my 181g gets REAL HOT REAL FAST. Even on the lowest setting, with the lid closed it sneaks up to almost 400 degrees. Slick little grill, just keep an eye on it. 4. The PahaQue eyebrow works great, once the sun was in the western sky...... And yes. it has a red stripe - someone ordered it and did not pick it up so I got it half price. Red's OK. The awning is a real nice piece of work. 5 - 10 mph gusts no problem. If it seems like I'm getting some hard lessons here, well not really - at least I'm not sleeping on the ground anymore and the margaritas are real cold after camp is set up. More trips planned as the weather gets warmer, will of course be moving up in elevation or latitude or both. Next time, no hook-ups. Battery and solar panel test time. Pictures attached, had to stop for that Nevada sunset - The adventures of the banjo pod continue! V/r; 68LC
You give peace a chance. I'll stay back here and cover you, in case things don't work out.
V/r;
68LC
2014 181g, now a 2017 180
Posted: 08 Mar 2015 at 7:40pm |
If you look in pod mods you will see how many deal with water. Lots of filters. We drink bottled water and use the campground water for washing and flushing.
2011 R-Pod 177
2010 Ford F-150
Leo B
Posted: 08 Mar 2015 at 8:14pm |
Nice set up for the 181g! We are the same...............drink bottled water and use the campground water the same.
Joe-n-Terri
Posted: 09 Mar 2015 at 9:49am |
Learned your lesson #1 this weekend as well as the keep vent open for condensation and put a heat barrier under the mattress lessons. Amazing what a maiden voyage will uncover.
Joe & Terri
2015 179
2015 Ram 1500 crew cab/ eco diesel
2005 Ram 1500/ Tekonsha Controller
Lovestarved Pom/Demanding Chihuahua
john in idaho
Posted: 09 Mar 2015 at 10:14am |
Not familiar with the awning. Where is it from again?
Posted: 09 Mar 2015 at 10:57am |
Ditto, after several "issues" we could only trace back to the water, we started using bottled water for trips. With the side benefit of not worrying about taste. No problems since.
Seanl
Posted: 09 Mar 2015 at 1:44pm |
Originally posted by john in idaho
Not familiar with the awning. Where is it from again? |
You can get one here.
ChinookPod
Posted: 09 Mar 2015 at 8:24pm |
Lesson learned about a "heat barrier" under the mattress - enough condensation to soak the sheets and the mattress, necessitating mattress removal to dry.
2014 RP171 HRE
2010 F150
D. K. CAMPERS
Posted: 09 Mar 2015 at 9:16pm |
Hi everyone, our 179 is still at the dealers because of the weather around here. I go to visit it once a week taking measurements and looking around. One thing that really troubles me is the outside door does not lay flat against the trailer when it is open. Has anyone considered wanting to have a door that hinges the other way? I meant to take some measurements the other day to see if it was even possible, but too much snow to do it, anyone have any thoughts on this? I would very much like to hear from you.
Deb and Kathy
D. K. CAMPERS
Posted: 09 Mar 2015 at 9:18pm |
How did this moisture problem happen.
Deb and Kathy
