Forum Home Forum Home > General Camping > Cook'n With Gas > Pressure cookers
  New Posts New Posts RSS Feed: smoke detector
Topic Closedsmoke detector
campingnut View Drop Down
Direct Link To This Post Topic: smoke detector
    Posted: 17 Dec 2014 at 3:12pm
Our smoke detector started beeping. Opened the detector and found no 9V battery. Put in a new battery. Still keeps beeping. Any fixes?
Al & Kathy
R-Pod 177
'98 Toyota 4Runner
Direct Link To This Post Posted: 17 Dec 2014 at 3:19pm
It isn't the smoke detector. My bet is your battery is low for the pod, and it's the propane detector.
Direct Link To This Post Posted: 17 Dec 2014 at 3:54pm
It is the smoke detector beeping. Thanks, just reposted this question under maintenance tips.
Al & Kathy
R-Pod 177
'98 Toyota 4Runner
Keith-N-Dar View Drop Down
Direct Link To This Post Posted: 17 Dec 2014 at 6:58pm
If there was no battery it wasn't  beeping.  I agree with Furpod.  I had the same trouble when we first got ours.
2011 R-Pod 177
2010 Ford F-150
hogone View Drop Down
Direct Link To This Post Posted: 17 Dec 2014 at 9:04pm
i'm going to slightly (just a little!!!) disagree hear.  a smoke detector can beep for a period of time even after removing the battery.  but i agree, i don't think this is the problem as campingnut mentioned it did not even have a battery in it to begin with.  hogone
Jon & Pam
2025 GD 17MKE
2013 RP177(sold Nov 25)
2023 F150
CHEESEHEAD
Direct Link To This Post Posted: 18 Dec 2014 at 8:33am
You have 3 detectors in the pod, smoke, carbon monoxide, and propane. Propane is the only one that is hardwired, and usually when people think they have a beeping smoke detector, they actually have a beeping propane detector because it "alarms" at about 11.5v for some reason. I have never had a smoke detector or cO detector that gave more than 1 or two beeps after the battery was removed.
The smoke detector can be removed by giving it a counter clockwise twist. Remove it from the pod, take it in the house. If it's still beeping, with a new battery in it, replace it. The pod is a very small space and it's often very hard to tell where a beep might be coming from.
Direct Link To This Post Posted: 18 Dec 2014 at 9:44am
Since this thread is in the wrong location, but the OP already started an identical thread in the correct location, let's move the discussion there...
