  <title>R-pod Owners Forum : smoke detector</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Pressure cookers : smoke detector</description>
  <pubDate>Fri, 23 Oct 2026 05:22:08 +0000</pubDate>
  <lastBuildDate>Thu, 18 Dec 2014 09:44:57 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=5632</WebWizForums:feedURL>
   <title>smoke detector :   Since this thread is in the...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=5632&amp;PID=55069#55069</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 5632<br /><strong>Posted:</strong> 18 Dec 2014 at 9:44am<br /><br />Since this thread is in the wrong location, but the OP already started an identical thread in the correct location, let's move the discussion there...<div>&nbsp;</div><div><a href="http://www.rpod-owners.com/forum_posts.asp?TID=5633&amp;title=beeping-smoke-detector" target="_blank">http://www.rpod-owners.com/forum_posts.asp?TID=5633&amp;title=beeping-smoke-detector</a></div>]]>
   <pubDate>Thu, 18 Dec 2014 09:44:57 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=5632&amp;PID=55069#55069</guid>
   <title>smoke detector : You have 3 detectors in the pod,...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=5632&amp;PID=55066#55066</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=936" rel="nofollow">furpod</a><br /><strong>Subject:</strong> 5632<br /><strong>Posted:</strong> 18 Dec 2014 at 8:33am<br /><br />You have 3 detectors in the pod, smoke, carbon monoxide, and propane. Propane is the only one that is hardwired, and usually when people think they have a beeping smoke detector, they actually have a beeping propane detector because it "alarms" at about 11.5v for some reason. I have never had a smoke detector or cO detector that gave more than 1 or two beeps after the battery was removed. <br><br>The smoke detector can be removed by giving it a counter clockwise twist. Remove it from the pod, take it in the house. If it's still beeping, with a new battery in it, replace it. The pod is a very small space and it's often very hard to tell where a beep might be coming from.<br>]]>
   <pubDate>Thu, 18 Dec 2014 08:33:21 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=5632&amp;PID=55066#55066</guid>
   <title>smoke detector :   i&amp;#039;mgoing to slightly...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=5632&amp;PID=55062#55062</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1821" rel="nofollow">hogone</a><br /><strong>Subject:</strong> 5632<br /><strong>Posted:</strong> 17 Dec 2014 at 9:04pm<br /><br />i'm&nbsp;going to slightly (just a little!!!) disagree hear.&nbsp; a smoke detector can beep for a period of time even after removing the battery.&nbsp; but i agree, i don't think this is the problem as campingnut mentioned it did not even have a battery in it to begin with.&nbsp; hogone]]>
   <pubDate>Wed, 17 Dec 2014 21:04:15 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=5632&amp;PID=55062#55062</guid>
   <title>smoke detector : If there was no battery it wasn&amp;#039;t...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=5632&amp;PID=55054#55054</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=807" rel="nofollow">Keith-N-Dar</a><br /><strong>Subject:</strong> 5632<br /><strong>Posted:</strong> 17 Dec 2014 at 6:58pm<br /><br />If there was no battery it wasn't&nbsp; beeping.&nbsp; I agree with Furpod.&nbsp; I had the same trouble when we first got ours.]]>
   <pubDate>Wed, 17 Dec 2014 18:58:21 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=5632&amp;PID=55054#55054</guid>
   <title>smoke detector : It is the smoke detector beeping....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=5632&amp;PID=55048#55048</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=512" rel="nofollow">campingnut</a><br /><strong>Subject:</strong> 5632<br /><strong>Posted:</strong> 17 Dec 2014 at 3:54pm<br /><br />It is the smoke detector beeping.  Thanks, just reposted this question under maintenance tips.]]>
   <pubDate>Wed, 17 Dec 2014 15:54:27 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=5632&amp;PID=55048#55048</guid>
   <title>smoke detector : It isn&amp;#039;t the smoke detector....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=5632&amp;PID=55046#55046</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=936" rel="nofollow">furpod</a><br /><strong>Subject:</strong> 5632<br /><strong>Posted:</strong> 17 Dec 2014 at 3:19pm<br /><br />It isn't the smoke detector. My bet is your battery is low for the pod, and it's the propane detector.]]>
   <pubDate>Wed, 17 Dec 2014 15:19:18 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=5632&amp;PID=55046#55046</guid>
   <title>smoke detector : Our smoke detector started beeping....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=5632&amp;PID=55045#55045</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=512" rel="nofollow">campingnut</a><br /><strong>Subject:</strong> 5632<br /><strong>Posted:</strong> 17 Dec 2014 at 3:12pm<br /><br />Our smoke detector started beeping.  Opened the detector and found no 9V battery.  Put in a new battery.  Still keeps beeping.  Any fixes?]]>
   <pubDate>Wed, 17 Dec 2014 15:12:47 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=5632&amp;PID=55045#55045</guid>
