creating an instruction & maintenance manual |
Page <1 910111213 25> |
Joined: 03 Apr 2011 Location: Mayville, WI Online Status: Offline Posts: 1447 |
Topic: creating an instruction & maintenance manualPosted: 25 Oct 2013 at 9:16pm |
If you are talking about the water heater the drain is the anode, and that is a big plug on the front of the heater (the side facing out). If not the heater then I don't know what hot water tank you are referring to.
k4fcp
Joined: 16 Jan 2013 Location: Blacksburg, VA Online Status: Offline Posts: 25 |
Posted: 26 Oct 2013 at 2:11am |
Thanks! I was just looking at the posted IM and it said to drain the hot water heater from outside...and there is/are two plugs underneath near the driver side wheel.
Rich
2013 R-177 2013 Ford F 150 4X4 (yeah, bought a new truck)! |
Posted: 26 Oct 2013 at 8:31am |
Those are the low point drains for the water system on my 177. While I suppose theoretically you could drain at least some of the heater from there if you had lots of time, I recommend the main drain where the anode goes in. Drains in seconds and gets almost all the water out.
Posted: 27 Oct 2013 at 10:12pm |
Several times I've just drained from the low point drains, opening up all the faucets and the over pressure valve to break the vacuum. It does take about 10 minutes though.
rebecca
Joined: 26 Jan 2014 Location: United States Online Status: Offline Posts: 2 |
Posted: 27 Jan 2014 at 8:50am |
rebecca
Posted: 27 Jan 2014 at 8:54am |
Hi! I'm new to the site and hope I'm posting in the correct spot!! I have a 2011 176T, and was soooo excited to fine this forum. After reading some posts - where is the low point drain - am I missing something other than the grey water drain? Thanks, #havepatience
wingnut2312
Joined: 25 Aug 2013 Location: MI Online Status: Offline Posts: 231 |
Posted: 27 Jan 2014 at 9:02am |
The low point drains should be in front of your passenger side wheel, under the fresh water fill. There is also a black water drain. I have a 186g so I don't know if this is the exact spot. Either way, look for two small drains, next to each other, with black caps. They will be on the outer edge.
2014 rpod 182G
Ford Expedition |
Posted: 27 Jan 2014 at 9:48am |
Welcome. Yes, the low-point drains should be somewhere along the bottom edge on the left side (as you face forward). There will be two of them hanging down.
Thinkcooper
Joined: 24 Jan 2014 Location: Santa Cruz, CA Online Status: Offline Posts: 50 |
Posted: 29 Jan 2014 at 12:44pm |
One thing this newbie podder noticed seems to be missing? Gray Water/Black Water labeling on the pod, and draining. My 177 has labels and two drains for Waste Water and Sewer Water. Not sure which is Black, which is Gray, and what the best process is for handling / dumping the nasty water. Any gloves you guys use, or process to keep from making a mess?
wingnut2312
Posted: 29 Jan 2014 at 1:03pm |
Use golves. Make sure your emptying tube is connected before you open the drain. Past that, don't get on you're shoes!! ;-)
2014 rpod 182G
Ford Expedition |
