creating an instruction & maintenance manual |
Page <1 56789 25> |
Joined: 29 Jul 2009 Location: MD Online Status: Offline Posts: 9066 |
Topic: creating an instruction & maintenance manualPosted: 12 Dec 2012 at 8:41pm |
Dealing with sway Original discussion here: http://www.rpod-owners.com/forum_posts.asp?TID=3141&PN=1&title=crashed-on-the-interstate-while-towing-the-rpod The biggest contributors to sway, in this order: 1. Not enough tongue weight2. Distance between rear axle and the hitch ball 3. Speed4. Short wheelbase vehicle 5. Camper tongue is pointed up, not level or pointed slightly down. 7. Lack of sway control 8. Outside forces like side winds, etc.
When sway starts ... Edited to add the new #2 above. |
betsypgarmy@yahoo.co
Joined: 02 Jun 2012 Location: Nebraska Online Status: Offline Posts: 19 |
Posted: 16 May 2013 at 12:38pm |
Why is it best to have Axle Risers? We have a 2012 RPod and pull it with a 2012 Highlander V6.
As you can tell, we are Newbies at this travel trailer thing! Betsy and Jim and the two Scottie's ![]() |
CharlieM
Posted: 16 May 2013 at 12:49pm |
The axle risers add about 4 inches to the ground clearance. This is important for dips in driveways, roads, gas station entrances and speed bumps. The rear leveler jacks are particularly vulnerable, as are bikes if you have them on the rear. My dealer said risers are worth their weight in gold; he was right.
wagnert
Joined: 09 Jan 2012 Location: Gig Harbor, WA Online Status: Offline Posts: 21 |
Posted: 16 May 2013 at 3:11pm |
The Hood River edition (made in Oregon) of the 2012 R-Pod came with oversize tires which, in my case, at least, have added enough ground clearance that I've not had any problems.
We've put on many thousands miles, been in many situations, never a problem. Tom Wagner 2012 R-Pod 177 2003 Toyota Sienna |
Tom Wagner
Posted: 16 May 2013 at 3:16pm |
Thanks for these suggestions
Jim and Betsy 2012 RPod 2012 Highlander
wagnert
Posted: 16 May 2013 at 3:30pm |
I just went outside to "read" my R-Pod tires.
Markings on tires: Mudstar Radial M/T LT 235/75 R15 As I mentioned, my R-Pod came with these tires. When I was buying, I asked the dealer why the rig had such big tires. He gave a non-answer, but I came to realize it was for the extra height they provided. |
Tom Wagner
Joined: 03 Apr 2011 Location: Mayville, WI Online Status: Offline Posts: 1447 |
Posted: 16 May 2013 at 7:11pm |
They come with the risers too. |
novapods
Joined: 14 Jan 2013 Location: Nova Scotia Online Status: Offline Posts: 13 |
Posted: 19 May 2013 at 11:52am |
Thanks for this!
We're currently camping for the first time now, picked up our rpod 178 Friday in Ontario. We'll go back home through the States to Nova Scotia. Lots to learn, and questions adding up too. |
TopJimmy5150
Joined: 05 Jun 2013 Online Status: Offline Posts: 23 |
Posted: 12 Jun 2013 at 1:15pm |
Nice thread.
I just brought home our 178 on Monday and have lots of questions, coming from a Pop-up with few amenities to this luxury suite on wheels.
1. On the checklist, it mentions sanitizing the fresh water tank. Does this have to be done with every trip? I'm not crazy about handling bleach and keeping it in the pod...bad experience when I was a kid.
2. I cannot figure out how to correctly empty the fresh water tank. The owners manual has a picture of some valve, however I could find nothing like that on my pod. There appears to be a drain on the bottom of the white tank that is towards the back (bottom) of the pod....is that what I use?
3. A few years ago we were camping in Saco, ME and our neighbors burned out their electrical system just by plugging into the campground power. I assume that the directive "Test Shore Power with Volt Meter" is to prevent this....I can purchase one...any recommendations, and what do I look for as far as red flags when I test it?
Thanks in advance.
Jay
2014 R-Pod RP178 2015 Toyota Tundra SR5 Crewman 2008 Honda Odyssey |
Posted: 12 Jun 2013 at 9:48pm |
1. Only at the start of the camping season. 2. To drain the fresh water tank you would use the drain on the bottom, but that is only necessary at the end of the season when you winterize. 3. Yes, any cheap $12 digital voltmeter will be fine. Make sure it is set to AC mode (look for the ~ sign) in a range that is more than 120 volts. Usually that setting will be 200. Just make sure it is between 110 and 128 volts. Be careful if it is near those limits. Lately I've just been using my Kill-A-Watt meter, and I leave it plugged in inside the pod during the stay to keep an eye on the voltage. |
Page <1 56789 25> |
