  New Posts New Posts RSS Feed: Dome Tent
Topic ClosedDome Tent
The E Train View Drop Down
Direct Link To This Post Topic: Dome Tent
    Posted: 28 Aug 2012 at 9:35pm
With the dome off, I opened the door all the way and looked at it. The top of the door extends over and past the roofline as the roofline curves downward. There may be no way around it for some models.
2002 Dakota (pulling a) 2012 R-Pod 176T
Paige View Drop Down
Direct Link To This Post Posted: 28 Aug 2012 at 9:12pm
We tried our rpod dome for the first time and I thought I had placed it wrong because the door hit the side roof truss and we couldn't open it all the way. Guess we are not alone?
Paige and Pete
2010 177 - RPug
2012 Rav (six cylinder)
New York & Florida residents
Direct Link To This Post Posted: 28 Aug 2012 at 6:51pm
Anyone else have this problem, or is it just my 176T.... With the dome up, I cannot open the door past 1/2 way (straight out) because it hits the dome. If I try to open it up more, it would rip through the dome roof.
Iteach5th View Drop Down
Direct Link To This Post Posted: 25 Aug 2012 at 6:20pm
Instead of using suction cups on the ends I tie it down with some parachute chord to the spare tire and the hitch. The suction cups just don't work,
I cut the screen into two parts one for infront of the tire and one  behind it, It's long enough to put over the steps.
2011 RP-177
2009 Jeep Cherokee
1982 Coleman Redwood pup
Goose View Drop Down
Direct Link To This Post Posted: 25 Aug 2012 at 11:18am
  First go along the track and set the screws down tight, sometimes the factory does not do this and it makes a big difference. Second buy a can of silicon spray to lub the track and the bead on the R-Dome. Any hardware store, camping store, Walmart should have it, one can goes a long way.
  The difference is night and day.    Goose
Direct Link To This Post Posted: 25 Aug 2012 at 7:21am
Is there a lubricant spray that can help slide the rdome through the track. It took both of us, pulling and pushing to get it through. This was our first outing in our "new" RPod. The edges were frayed from the previous owner. The rdome kept snagging at regular intervals along the track. It took longer by far to get it through the track than to set it up the rest of the way.
Paige and Pete
2010 177 - RPug
Pod People View Drop Down
Direct Link To This Post Posted: 12 Mar 2012 at 9:58pm
We did 2 things to help make the slide easier--I used a small file and smoothed/rounded  the cut edges at the end of the track and I used a burr bit on the end of a battery powered drill to smooth the heads of all of the screws inside the track.  another podder showed an attachment to the leading edge of the tent slider that one can use to pull it along the track.  It was a piece of nylon webbing that was riveted or sewn into the slider material to make a "leash" to pull with.
we also have the 3 snaps screwed onto each side of our rpod to hold the rdome tight against the sides-they are stiff, but will not come loose in a wind or storm.
we love our rdome
Vann Evans
Pod People
Direct Link To This Post Posted: 12 Mar 2012 at 1:40pm
Spray the track with silicone spray.. ours pushes through smooth as glass.
We found the stakes that came with the dome to be useless, went to wally world and bought two packs of real stakes for about $6. I have pounded them into packed gravel with no problem.
Direct Link To This Post Posted: 11 Mar 2012 at 9:51pm
I've seen shavings, which I think come from the screw heads inside the track.
Bill-GA View Drop Down
Direct Link To This Post Posted: 10 Mar 2012 at 11:08pm
Another comment on the tent ... When I put the ribbed edge of the Dome tent into the slot over the door, my first inclination was to pull it along with a pair of pliers. That turned out near impossible and instead I PUSHED it in and was surprised how easily it went into the slot. The only downside was that I noticed some 'shaved' inch+ pieces of the plastic rib at my feet. I think I will take a small file and round off sharp edges of the slot oppening to prevent this next time.
Has any tent owner experienced  this too? Is there a better method? The prev owner said he sprayed some silicon in the slot to make it slide better.
Bill & Bev
13 yr old dachshund 'Elsa'
2011 Toyota Tundra 2WD TV
