  New Posts New Posts RSS Feed: r-pod Axle Riser
Topic Closedr-pod Axle Riser
Direct Link To This Post Topic: r-pod Axle Riser
    Posted: 14 May 2012 at 1:25pm
I had to clip one zip tie on each side to allow the brake wires to lengthen some.  No need to actually extend the wires.  NOTE, I found my brake wires on one side had gotten between the axle and frame and at some point I hit something that took up all of the suspension travel, which pinched the wires completely in half.  I made sure the wires took a slightly different route when I was done adding the risers.
Chuck View Drop Down
Direct Link To This Post Posted: 14 May 2012 at 11:58am
When I did ours last Fall there was no need to lengthen the brake lines. I think it just a CYA. I love my risers. Not as attractive as I'd like but the hassle free in/out of the driveway and other uneven surfaces is absolutely worth it!
Z-pod
Chuck Janet & Bogie the dog
'12 RP 177
1972 Shasta 1400
2005 Ford F-150 5.3L V8
Panama Red View Drop Down
Direct Link To This Post Posted: 14 May 2012 at 10:57am
In the Riser pdf. instructions, FR mentions "adding splices if necessary" to the electric brake lines, but nobody on the form has ever mentioned having to "add splices if necessary" to the brake lines !!!!
Is this statement by FR, just a CYA, or do you actually have to adjust the brake lines after installing the Riser ???
Gerald View Drop Down
Direct Link To This Post Posted: 08 Feb 2012 at 1:16pm
Loctite won't be necessary as the supplied bolts are self locking.
2010 R-Pod 177 / 2009 GMC Canyon 4X4
Gerald, Lydia and The Boys (2 Shelties)......Canuck Podders
rudyunknown View Drop Down
Direct Link To This Post Posted: 07 Feb 2012 at 4:28pm
i just got the axel risers from Brandon, she wanted the last 4 of the VIN to get me the correct risers. I am handy with tools, will try to install them when i have the rpod on my property in march, i will take some pictures to post them and if i screw up something. I dont have a impact wrench, so i am not sure how long before i can break the factory bolt...i am assuming loctite should go back on the bolt when putting it back together?
2011 Rpod 171
Tundra
Rudy Reshmi n big Omkar n lil Arjun
tpierce220 View Drop Down
Direct Link To This Post Posted: 05 Feb 2012 at 9:53am
We were at Collier's yesterday to measure the pod for curtains, and they had a 177 parked behind ¡Podtástic!  I took some pictures, too, just so that you can really see the difference between our pod with the riser and the 177 without it.
It's going to make dumping so much easier.
Tidalwave4455 View Drop Down
Direct Link To This Post Posted: 24 Jan 2012 at 6:14pm
You need to have the tools to break loose the factory bolt.  Either an extension for your heavy duty socket wrench or a pneumatic impact wrench (which I used).  I also made sure that I had a hydraulic jack and a couple of jack stands to safely hold the Pod up.  I am not a mechanic...but it only took me about 1/2 hour to install the risers and then a few minutes to put the wheels back on.
Having sturdy enough tools makes all the difference in the world.
Direct Link To This Post Posted: 24 Jan 2012 at 8:03am
My dealer quoted me $100 for the install but I did it myself. The $100 looked like a really good deal after about 2.5 hours on my back with blood running down my sleeve from busted nuckels. But then again I have the satisfaction of having done it myself. That being said, no matter who installs them, they are one of the very best mods I've done.
Z-pod
'12 RP 177
1972 Shasta 1400
Kickstart View Drop Down
Direct Link To This Post Posted: 23 Jan 2012 at 9:17pm
Bill,the risers come from Forest River w/diagrams and install info that would make the install pretty straigt forward for anyone that feels comfortable with most shade tree wrenching jobs. If you farm it out, then figure 3/4 to 1 1/2 hours of shop time. I know, but for shoulder surgery, I would have done ours, and I'm no mechanic.
Incidently, the dealer we purchased our Pod from beat your dealer. They would have done the job for $400.
Direct Link To This Post Posted: 23 Jan 2012 at 7:45pm
Especially when you can order them yourself from FR for less than $100!
