  New Posts New Posts RSS Feed: Anode Rod Replacement
Topic ClosedAnode Rod Replacement
Direct Link To This Post Topic: Anode Rod Replacement
    Posted: 19 Nov 2011 at 7:04pm
 On the Camping World website they have a anode rod for the atwood hot water heaters with a built in valve. Is there one avialable with a vave for the suburbon hot water heaters? Or would the attwood anode rod work for the suburbon?    David
  I just found out the atwood and suburbon have different size diameter pipe threads one 1/2" and the other 3/4".
2014 Ram 1500 Quad cab
Direct Link To This Post Posted: 18 Nov 2011 at 10:11pm
The big guys have anode rods, too, inserted from the top.  If you check it (or get a plumber to check it) every 5 years your tank might last a very long time.  But most people don't, and so they rust through.
dsmiths View Drop Down
Direct Link To This Post Posted: 18 Nov 2011 at 9:06pm
Being weak in chemistry, why does the small travel trailer water heater need a sacrificial anode and house water heaters do not ? I understand electrolis, but what if its operated on gas only ?
Dane and Donna Smith
2011 RP-172
lift kit
Podsible Dream View Drop Down
Direct Link To This Post Posted: 18 Nov 2011 at 5:56pm
You got the chemistry right! See you're right there with the rest of us techies!
Chris and Walt
'10 RP-171 'Free Spirit'
Direct Link To This Post Posted: 18 Nov 2011 at 1:25pm
I agree with turncoat3.  I have found that about midway thru the season I start getting the infamous "rotten egg" smell in the hot water.  I forget the name of the gas that is generated during use (hydrogen sulfide???).  So, in my case, I like to drain and flush at least twice per season.  Once during winterization and then again as stated above.
turncoat3 View Drop Down
Direct Link To This Post Posted: 18 Nov 2011 at 10:38am
I believe that FR uses several different models of water heaters so be sure that you know the model number.  I would recomend removing the anode at least twice a year for inspection and retaping.
Ben & Lorrie
2013 Surveyor 264
Direct Link To This Post Posted: 17 Nov 2011 at 2:05pm
Yes and no.  If you remove the rod (as is good) for inspection, whatever....remove any of the old tape (it will be shredded somewhat during removal) and wrap with fresh.
The tape helps seal the threads against leaks and make it easier to remove, later.  If you were to never remove it, it would likely last "forever".
Hodge-PODge View Drop Down
Direct Link To This Post Posted: 17 Nov 2011 at 1:51pm
Is the teflon tape supposed to remain on the rod indefinitely?
2011 RP 177, the Hodge-PODge
2011 Mercedes ML350
tdrace View Drop Down
Direct Link To This Post Posted: 16 Nov 2011 at 9:39pm
Thanks for all the info
tdrace's
2018 180
2010 FORD F150 V-8
equalizer e-2 hitch
Sisters on the Fly #1569
Direct Link To This Post Posted: 16 Nov 2011 at 9:37am
My local RV dealer was $16.
