Footslogger03
Topic: Bike Rack Posted: 19 Aug 2011 at 9:52am |
Can't tell from the brochure ...so I thought I'd check with the group.
It's my understanding that the spare tire assembly fits into a standard trailer hitch on the R-Pod.
It"s also my understanding that the bike rack assembly works with then trailer hitch. In other words, does the bike rack fit "over" the hitch tongue of the spare ...or is it an "either/or" situation.
I know that Thule and Yakima make bike rack assemblies that fit "over" the tongue so that you can use a standard hitch ball and the bike rack at the same time.
My question is ...can they both be used at the same time on the R-Pod ? - - and is it a 2" hitch receiver?
Thanks in advance,
MJ
Livin' the Dream ...'Slogger
Damour
Posted: 19 Aug 2011 at 10:35am |
For us the bike rack is at the front, over the propane tank
They say that it'll "swing" less than if it's installed at the rear.
It works well for our 2 bikes
rp 171 , from Québec with not a good english writing lol
TerryM
Posted: 19 Aug 2011 at 10:49am |
Here is what I use:  But then I can't hookup the camper!  Actually the bike goes in (all 7' 10" of it) the R-Pod when traveling. This doesn't help you at all does it! Sorry!  Terry
Footslogger03
Posted: 19 Aug 2011 at 11:15am |
Just so I understand correctly ...you have the actual R-Pod bike rack option and you have it hooked up to the hitch bar near the ball on your tow vehicle?
I am trying to find a way to keep the spare tire mounted on the rear of the pod and put 2 bikes back there too.
They (Thule and Yakima) make bike racks that fit over the actual spare tire, instead of being part of a bar assembly that plugs into a hitch receiver. So I guess my next question would be ...can the R-Pod spare tire assembly handle the weight of "wheel mount" rack and 2 bikes ?
Thanks again ....
MJ
Footslogger03
Posted: 19 Aug 2011 at 11:19am |
I'm familiar with this type of trailer hitch "tray/rack" and thought that might be an option for thenrear of the R-pod, since (if I understand correctly), there is a conventional hitch receiver back there. Do you know off-hand if that is true and ...is it a 2" receiver?
Thanks,
MJ
Posted: 19 Aug 2011 at 11:58am |
As far as I know the receiver on the 'pod is a standard 2" receiver, but it has a weight limit of I believe 150 pounds. Don't quote me on that. I agree that you don't want to put your bikes back there along with the tire, or one of those cargo trays. Ignoring the possible 150 pound limit, its a lot of mass that will give you a pendulum effect that will contribute to sway. And those trays stick out quite a bit which will give it even more momentum.
Considering issues with turning clearance if you put bikes between the TV and 'pod, and problems getting to stuff in the back of a TV if you hang them off the back of your TV, I've decided that when the time comes (soon), I'm going to have a second 2" receiver mounted on the front of my TV. Then I can put any receiver-style bike rack up there or one of those cargo trays. I've heard of people also using this to park their campers in tight spots - easier to see and more maneuverable when its hitched up to the front of your TV.
PaddyMorris
Posted: 19 Aug 2011 at 6:52pm |
It is a 1 1/4". I put an adapter on my sport rack and it carried two bikes nicely.
PaddyMorris
Posted: 19 Aug 2011 at 6:53pm |
Originally posted by PaddyMorris
It is a 1 1/4". I put an adapter on my sport rack and it carried two bikes nicely. |
I meant the spare tire receiver...
PaddyMorris
Posted: 19 Aug 2011 at 6:54pm |
Originally posted by TerryM
Here is what I use:
Terry
what is that thing? Awesome, you make it or buy it?
Guests
Posted: 19 Aug 2011 at 9:36pm |
He's just showing off his cool bike
