Fender Reattachment 2018 RP-171 |
jshectman
Joined: 10 Nov 2025 Location: NC Online Status: Offline Posts: 6 |
Topic: Fender Reattachment 2018 RP-171Posted: 18 May 2026 at 7:28am |
Hi! I’ve had it about a year. The passenger side fender is rock solid but the drivers side (by the Rpod’s entry door) has ripped off. I repaired the LED but the screws just pull out of the holes. Looking for advice on how to best reattach it correctly (do it once, do it right). A size wider screw? Longer screws? I thought about well nuts but the holes are only about 3mm wide and I don’t see any well nuts that small.
Advice? Thank you! ![]() Edited by jshectman - 18 May 2026 at 7:56am |
JR
Joined: 31 Aug 2018 Location: Manistee, MI Online Status: Offline Posts: 408 |
Posted: 18 May 2026 at 8:34am |
What I did when about half the screws were not holding any longer and the fender was about to fall off was I filled the old holes with some weather proof sealant. After the old holes were filled I drilled new starter holes in the fender and trailer wall (about a half inch away fromt he old holes) and got some good caulk/mastic and liberally put that between the fender and the wall of the trailer. Then installed the screws into the fender/wall. When the fender was attached I put a good bead of caulk/mastic on the visible fender joint with the wall. I used black caulk/mastic for appearance sake. I have had no problem with the fender since, hope this helps.
Jay
179/2019 |
jshectman
Posted: 18 May 2026 at 3:14pm |
Hi Jay, that's a terrific idea. I had for some reason not thought of it. I can fill the holes in with Dicor and then maybe move the fender up slightly so the original holes wont really be seen...or similar.
Did you use Dicor/mastic/sealant between the fender and the siding as well as on top of the siding? Many, many thanks! Jon
Edited by jshectman - 18 May 2026 at 3:15pm |
JR
Posted: 18 May 2026 at 3:47pm |
I didn't use "Dicor" but just used a good quality mastic/caulk. But dicor would work well.
Jay
179/2019 |
jshectman
Posted: 21 May 2026 at 2:09pm |
Thank you again so much mate!
