  <title>R-pod Owners Forum : Fender Reattachment 2018 RP-171</title>
  <description>This is an XML content feed of; R-pod Owners Forum : I need HELP!!! : Fender Reattachment 2018 RP-171</description>
  <pubDate>Fri, 23 Oct 2026 10:23:58 +0000</pubDate>
  <lastBuildDate>Thu, 21 May 2026 14:09:40 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=16442</WebWizForums:feedURL>
   <title>Fender Reattachment 2018 RP-171 : Thank you again so much mate! </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=16442&amp;PID=155537#155537</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=14144" rel="nofollow">jshectman</a><br /><strong>Subject:</strong> 16442<br /><strong>Posted:</strong> 21 May 2026 at 2:09pm<br /><br />Thank you again so much mate!]]>
   <pubDate>Thu, 21 May 2026 14:09:40 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=16442&amp;PID=155537#155537</guid>
   <title>Fender Reattachment 2018 RP-171 : I didn&amp;#039;t use &amp;#034;Dicor&amp;#034;...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=16442&amp;PID=155536#155536</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8731" rel="nofollow">JR</a><br /><strong>Subject:</strong> 16442<br /><strong>Posted:</strong> 18 May 2026 at 3:47pm<br /><br />I didn't use "Dicor" but just used a good quality mastic/caulk. But dicor would work well.]]>
   <pubDate>Mon, 18 May 2026 15:47:00 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=16442&amp;PID=155536#155536</guid>
   <title>Fender Reattachment 2018 RP-171 :  Hi Jay, that&amp;#039;s a terrific...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=16442&amp;PID=155535#155535</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=14144" rel="nofollow">jshectman</a><br /><strong>Subject:</strong> 16442<br /><strong>Posted:</strong> 18 May 2026 at 3:14pm<br /><br />Hi Jay, that's a terrific idea. I had for some reason not thought of it. I can fill the holes in with Dicor and then maybe move the fender up slightly so the original holes wont really be seen...or similar.<div><br></div><div>Did you use Dicor/mastic/sealant between the fender and the siding as well as on top of the siding?</div><div><br></div><div>Many, many thanks!</div><div>Jon</div><span style="font-size:10px"><br /><br />Edited by jshectman - 18 May 2026 at 3:15pm</span>]]>
   <pubDate>Mon, 18 May 2026 15:14:43 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=16442&amp;PID=155535#155535</guid>
   <title>Fender Reattachment 2018 RP-171 : What I did when about half the...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=16442&amp;PID=155533#155533</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8731" rel="nofollow">JR</a><br /><strong>Subject:</strong> 16442<br /><strong>Posted:</strong> 18 May 2026 at 8:34am<br /><br />What I did when about half the screws were not holding any longer and the fender was about to fall off was I filled the old holes with some weather proof sealant.&nbsp; After the old holes were filled I drilled new starter holes in the fender and trailer wall (about a half inch away fromt he old holes) and got some good caulk/mastic and liberally put that between the fender and the wall of the trailer.&nbsp; Then installed the screws into the fender/wall.&nbsp; When the fender was attached I put a good bead of caulk/mastic on the visible fender joint with the wall. I used black caulk/mastic for appearance sake.&nbsp; I have had no problem with the fender since, hope this helps.]]>
   <pubDate>Mon, 18 May 2026 08:34:40 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=16442&amp;PID=155533#155533</guid>
   <title>Fender Reattachment 2018 RP-171 : Hi! I&#226;&#8364;&#8482;ve had it about a year....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=16442&amp;PID=155532#155532</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=14144" rel="nofollow">jshectman</a><br /><strong>Subject:</strong> 16442<br /><strong>Posted:</strong> 18 May 2026 at 7:28am<br /><br />Hi! I’ve had it about a year. The passenger side fender is rock solid but the drivers side (by the Rpod’s entry door) has ripped off. I repaired the LED but the screws just pull out of the holes. Looking for advice on how to best reattach it correctly (do it once, do it right). A size wider screw? Longer screws? I thought about well nuts but the holes are only about 3mm wide and I don’t see any well nuts that small.<br /><br />Advice? Thank you!<img src="uploads/14144/Small_fender.jpg" border="0" /><span style="font-size:10px"><br /><br />Edited by jshectman - 18 May 2026 at 7:56am</span>]]>
   <pubDate>Mon, 18 May 2026 07:28:38 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=16442&amp;PID=155532#155532</guid>
