Slideout problems |
fishkiller
Joined: 26 May 2017 Location: USA Online Status: Offline Posts: 2 |
Topic: Slideout problemsPosted: 27 Apr 2026 at 7:00pm |
My 2014 177 rPod's slideout is stuck on the IN position. How do I fix it ? How do I even get to it to fix it ?
wthoms2000
Joined: 06 May 2017 Location: Costa Mesa, CA Online Status: Offline Posts: 46 |
Posted: 28 Apr 2026 at 1:18am |
Are you sure you have power to the slide out? Check the fuses?
Is there motor noise when pushing the OUT button? |
Porta Poddy
Wil and Luz, Orange County, CA 2017.5 179 HRE 2021 Ranger XLT FX4 REDARC Brake Controller |
gpokluda
Joined: 11 Nov 2018 Location: East Idaho Online Status: Offline Posts: 504 |
Posted: 28 Apr 2026 at 6:56am |
+1 start there. Does your battery have a charge? Are any sounds made when you press the switch? On a 179, there is a small control board under the fridge behind a slide panel. I believe it has a couple of led lights. That should tell you if power is making it to the controller.
Gpokluda
2017 Rpod 179(sold 2023) 2022 Escape 5.0TA 2022 Ford F150 4X4 3.5EB Honda SCL500 |
Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3439 |
Posted: 01 May 2026 at 5:18am |
Agree with the above. I had this happen on a couple occasions, once the battery was too low for the slide to operate, the other time there was some corrosion and a somewhat loose connection at the battery. After cleaning the battery post and properly tightening the connection, problem was solved. Have you tried plugging in to shore power to see if the slide will operate then?
