Slideout problems
URL: https://www.rpod-owners.com/forum_posts.asp?TID=16431
Printed Date: 04 Oct 2026 at 2:13am
Topic: Slideout problems
Posted By: fishkiller
Subject: Slideout problems
Date Posted: 27 Apr 2026 at 7:00pm
My 2014 177 rPod's slideout is stuck on the IN position. How do I fix it ? How do I even get to it to fix it ?
Posted By: wthoms2000
Date Posted: 28 Apr 2026 at 1:18am
Are you sure you have power to the slide out? Check the fuses?
Is there motor noise when pushing the OUT button?
Porta Poddy
Wil and Luz, Orange County, CA
2017.5 179 HRE
2021 Ranger XLT FX4
REDARC Brake Controller
Posted By: gpokluda
Date Posted: 28 Apr 2026 at 6:56am
+1 start there. Does your battery have a charge? Are any sounds made when you press the switch? On a 179, there is a small control board under the fridge behind a slide panel. I believe it has a couple of led lights. That should tell you if power is making it to the controller.
Gpokluda
2017 Rpod 179(sold 2023)
2022 Escape 5.0TA
2022 Ford F150 4X4 3.5EB
Honda SCL500
Posted By: jato
Date Posted: 01 May 2026 at 5:18am
Agree with the above.  I had this happen on a couple occasions, once the battery was too low for the slide to operate, the other time there was some corrosion and a somewhat loose connection at the battery.  After cleaning the battery post and properly tightening the connection, problem was solved.
Have you tried plugging in to shore power to see if the slide will operate then?
