  New Posts New Posts RSS Feed: Cooking in the RPod
Cooking in the RPod
LeonMBarnes View Drop Down
Post Options Post Options   Quote LeonMBarnes Quote  Post ReplyReply Direct Link To This Post Topic: Cooking in the RPod
    Posted: 20 Apr 2025 at 1:58pm
Help here will be much appreciated.
Do y'all do real cooking in your R-Pod? We don't believe there is any vent to the outside for the propane cook top . Even boiling water sometimes sets off the smoke alarm.
Thank you in advance,
Leon and Johanne Barnes
Adventures in Retirement
Post Options Post Options   Quote jato Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2025 at 8:07pm
We remove the battery from the detector when cooking if necessary.  Although the majority of our cooking is done on a charcoal grill (outside) a fair amount is still done inside but doesn't generate enough smoke to set detector off such as eggs, onions, veggies, beans, and the like.  Keep the window by the stove open a bit (177) and running the FF in the bathroom helps immensely.
Pod People View Drop Down
Post Options Post Options   Quote Pod People Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2025 at 9:58am
We cook almost all of our meals in our 179. However, we remove the smoke detector before cooking as it will almost always go off during the process.  We also usually open the door immediately  next to the cooktop and turn on the fan in the bathroom.
Travel often and safe
Vann
Vann & Laura 2015 RPod 179
James07 View Drop Down
Post Options Post Options   Quote James07 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2025 at 1:03pm
We just remove the smoke detector when it goes off.  Turning on the bathroom fan works too if you can stand the noise.  One time I cooked crab inside and it stunk up the place.  Never again.  I purchased an electric hot plate to cook seafood outside instead.
gpokluda View Drop Down
Post Options Post Options   Quote gpokluda Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2025 at 4:17pm
Unless it was something really easy like warming up soup, we cooked outside most of the time, even in less than perfect weather.
Gpokluda
2017 Rpod 179(sold 2023)
2022 Escape 5.0TA
2022 Ford F150 4X4 3.5EB
Honda SCL500
Frank_Balsamo View Drop Down
Post Options Post Options   Quote Frank_Balsamo Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2025 at 5:11pm
We have only had our 205 for 6 months and I only found out a few weeks ago that you have to manually open the vent exhaust on the outside wall, otherwise the smoke has nowhere to go.  But I still cook most things outside.
