  New Posts New Posts RSS Feed: ISO Axle Lift Kit
ISO Axle Lift Kit
kickhead70 View Drop Down
Post Options Post Options   Quote kickhead70 Quote  Post ReplyReply Direct Link To This Post Topic: ISO Axle Lift Kit
    Posted: 16 Jul 2024 at 12:13pm
Hello all,  i'm in search of an axle lift kit that is no longer made by lippert.  I have a 2017 RP180, but not the Hood River Edition, so it sits a bit low for my taste, and doesn't quite line up with my hitch (which is as low as it goes without a different drop - which may cost as much as a lift).
Does anyone have any resources I could check that I may be able to find one on a shelf in a warehouse somewhere?
thanks!
Wrangler Unlimitied 75th Anniv. Ed.
2017 R-Pod RP180
seafans View Drop Down
Post Options Post Options   Quote seafans Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2024 at 8:02am
Check Etrailer.  They have several lifts and with  different heights.  Hood River edition is about 2.5" to 3" higher?
Post Options Post Options   Quote GlueGuy Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2024 at 11:08am
You can also check with Forrest River, as I think they had a lift kit for non Hood River models. I do not recall the height, but I think it was a 2" lift.
Hardwear Hank View Drop Down
Post Options Post Options   Quote Hardwear Hank Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2024 at 2:38pm
I ended up purchasing the lift kit for a Dexter axle for my 192. Two holes line up perfectly, the other two need to be elongated towards center 1/4" each. My trailer now sit about 2 1/2" higher. I got tired of replacing my waste valves because they were so low, they were easily damaged by uneven roads. Very happy with the conversion. The Dexter part# is K71-724-01   the 01 means 1 set for single axle trailers.
Hope this helps someone.
Hardwear Hank
2021-192
Post Options Post Options   Quote Hardwear Hank Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2024 at 2:41pm
The Dexter kit is readily available, but it needs a minor modification see post below from Hardwear Hank
Dexter part# K71-724-01
Hardwear Hank
2021-192
