TOILET VALVE - Event Date: 27 Mar 2023 |
Page <123> |
gpokluda ![]() Senior Member ![]() ![]() Joined: 11 Nov 2018 Location: NM Online Status: Offline Posts: 417 |
![]() ![]() ![]() ![]() Posted: 03 Apr 2023 at 8:09pm |
Gpokluda
hogone ![]() Senior Member ![]() ![]() Joined: 09 Apr 2013 Location: High Ridge, MO Online Status: Offline Posts: 1063 |
I havent done mine yet; but just to confirm.......toilet held on by the two bolts (1 on each side). Just lift off like a "regular" toilet; correct? I assume the gasket (or whatever is under there) does not need to be relaced; correct? Just want to be sure. Thanks for the help. Jon
Jon & Pam
2013 RP177 2023 F150 2017 HD Streetglide CHEESEHEAD |
jato ![]() Senior Member ![]() ![]() Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3378 |
Jon, When I replaced the toilet it was already 6 years old, and it seems the replacement gasket was around $8, so it got replaced. Any RV store would carry it. Pretty easy to tell if the seal is good or not once you pull the toilet off, make sure when doing this you inhale deeply ![]() Pertaining to your other questions, you are correct as there are two bolts to remove and simply lift off like a regular toilet. Quite easy as being plastic doesn't require much effort to remove.
When you replace the toilet, be careful not to over torque the 2 flange bolts or you can end up damaging the plastic flange. Dometic gives a torque value in inch pounds in the installation instructions that you can probably find online.
thanks for the info you guys. Much appreciated. jon
Jon & Pam
I know Im a pain in the #%%! When I pull the toilet off, will the flange stay on the base or the toilet......or could it go either waY? jon
Jon & Pam
Mine stayed on the base, either way it will remove off the base or toilet quite easily. |
cool, thanks jato. jon
Jon & Pam
The flange is held to the floor with wood screws. If you want to take it off, you have to remove them.
bummer, just yanked toilet.......wrong valve. mine is model 31682. jon
Jon & Pam
Page <123> |
