  <title>R-pod Owners Forum : TOILET VALVE</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Podmods, Maintenance, Tips and Tricks : TOILET VALVE</description>
  <pubDate>Wed, 28 Oct 2026 11:33:25 +0000</pubDate>
  <lastBuildDate>Sat, 08 Apr 2023 16:35:07 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=15640</WebWizForums:feedURL>
   <title>TOILET VALVE : The only way to be certain is...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15640&amp;PID=151445#151445</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1146" rel="nofollow">jato</a><br /><strong>Subject:</strong> 15640<br /><strong>Posted:</strong> 08 Apr 2023 at 4:35pm<br /><br />The only way to be certain is to pressurize your line and see where the leak is, should be apparent with your commode removed.<br>]]>
   <pubDate>Sat, 08 Apr 2023 16:35:07 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15640&amp;PID=151445#151445</guid>
   <title>TOILET VALVE : you think it could be the elbow...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15640&amp;PID=151444#151444</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1821" rel="nofollow">hogone</a><br /><strong>Subject:</strong> 15640<br /><strong>Posted:</strong> 08 Apr 2023 at 3:31pm<br /><br />you think it could be the elbow in the pex?&nbsp; &nbsp; or the valve, or both?&nbsp; jon]]>
   <pubDate>Sat, 08 Apr 2023 15:31:51 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15640&amp;PID=151444#151444</guid>
   <title>TOILET VALVE : i think i need 31705. jon </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15640&amp;PID=151443#151443</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1821" rel="nofollow">hogone</a><br /><strong>Subject:</strong> 15640<br /><strong>Posted:</strong> 08 Apr 2023 at 2:49pm<br /><br />i think i&nbsp; need 31705.&nbsp; jon]]>
   <pubDate>Sat, 08 Apr 2023 14:49:41 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15640&amp;PID=151443#151443</guid>
   <title>TOILET VALVE : bummer, just yanked toilet.......wrong...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15640&amp;PID=151442#151442</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1821" rel="nofollow">hogone</a><br /><strong>Subject:</strong> 15640<br /><strong>Posted:</strong> 08 Apr 2023 at 1:29pm<br /><br />bummer, just yanked toilet.......wrong valve.&nbsp; mine is model 31682.&nbsp; jon]]>
   <pubDate>Sat, 08 Apr 2023 13:29:22 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15640&amp;PID=151442#151442</guid>
   <title>TOILET VALVE : The flange is held to the floor...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15640&amp;PID=151431#151431</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6036" rel="nofollow">lostagain</a><br /><strong>Subject:</strong> 15640<br /><strong>Posted:</strong> 06 Apr 2023 at 2:13pm<br /><br />The flange is held to the floor with wood screws. &nbsp;If you want to take it off, you have to remove them.]]>
   <pubDate>Thu, 06 Apr 2023 14:13:15 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15640&amp;PID=151431#151431</guid>
   <title>TOILET VALVE : cool, thanks jato. jon </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15640&amp;PID=151429#151429</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1821" rel="nofollow">hogone</a><br /><strong>Subject:</strong> 15640<br /><strong>Posted:</strong> 06 Apr 2023 at 10:22am<br /><br />cool, thanks jato.&nbsp; jon]]>
   <pubDate>Thu, 06 Apr 2023 10:22:16 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15640&amp;PID=151429#151429</guid>
   <title>TOILET VALVE : Mine stayed on the base, either...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15640&amp;PID=151428#151428</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1146" rel="nofollow">jato</a><br /><strong>Subject:</strong> 15640<br /><strong>Posted:</strong> 06 Apr 2023 at 9:12am<br /><br /><div>Mine stayed on the base, either way it will remove off the base or toilet quite easily.</div><div><br></div>]]>
   <pubDate>Thu, 06 Apr 2023 09:12:03 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15640&amp;PID=151428#151428</guid>
   <title>TOILET VALVE : I know Im a pain in the #%%! When...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15640&amp;PID=151427#151427</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1821" rel="nofollow">hogone</a><br /><strong>Subject:</strong> 15640<br /><strong>Posted:</strong> 06 Apr 2023 at 8:42am<br /><br />I know Im a pain in the #%%!&nbsp; When I pull the toilet off, will the flange stay on the base or the toilet......or could it go either waY?&nbsp; jon]]>
   <pubDate>Thu, 06 Apr 2023 08:42:30 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15640&amp;PID=151427#151427</guid>
   <title>TOILET VALVE : thanks for the info you guys....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15640&amp;PID=151408#151408</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1821" rel="nofollow">hogone</a><br /><strong>Subject:</strong> 15640<br /><strong>Posted:</strong> 04 Apr 2023 at 9:08pm<br /><br />thanks for the info you guys.&nbsp; Much appreciated.&nbsp; jon]]>
   <pubDate>Tue, 04 Apr 2023 21:08:57 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15640&amp;PID=151408#151408</guid>
   <title>TOILET VALVE : When you replace the toilet, be...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15640&amp;PID=151404#151404</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6036" rel="nofollow">lostagain</a><br /><strong>Subject:</strong> 15640<br /><strong>Posted:</strong> 04 Apr 2023 at 5:57pm<br /><br />When you replace the toilet, be careful not to over torque the 2 flange bolts or you can end up damaging the plastic flange. &nbsp;Dometic gives a torque value in inch pounds in the installation instructions that you can probably find online. &nbsp;]]>
   <pubDate>Tue, 04 Apr 2023 17:57:07 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15640&amp;PID=151404#151404</guid>
   <title>TOILET VALVE : Jon, When I replaced the toilet...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15640&amp;PID=151385#151385</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1146" rel="nofollow">jato</a><br /><strong>Subject:</strong> 15640<br /><strong>Posted:</strong> 04 Apr 2023 at 9:23am<br /><br /><div>Jon, When I replaced the toilet it was already 6 years old, and it seems the replacement gasket was around $8, so it got replaced.&nbsp; Any RV store would carry it.&nbsp; Pretty easy to tell if the seal is good or not once you pull the toilet off, make sure when doing this you inhale deeply<img src="https://www.rpod-owners.com/smileys/smiley36.gif" border="0" alt="LOL" title="LOL" />.&nbsp; <br></div><div><br></div><div>Pertaining to your other questions, you are correct as there are two bolts to remove and simply lift off like a regular toilet.&nbsp; Quite easy as being plastic doesn't require much effort to remove.<br></div>]]>
   <pubDate>Tue, 04 Apr 2023 09:23:37 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15640&amp;PID=151385#151385</guid>
   <title>TOILET VALVE : I havent done mine yet; but just...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15640&amp;PID=151383#151383</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1821" rel="nofollow">hogone</a><br /><strong>Subject:</strong> 15640<br /><strong>Posted:</strong> 04 Apr 2023 at 7:06am<br /><br />I havent done mine yet; but just to confirm.......toilet held on by the two bolts (1 on each side).&nbsp; Just lift off like a "regular" toilet; correct?&nbsp; I assume the gasket (or whatever is under there) does not need to be relaced; correct?&nbsp; Just want to be sure.&nbsp; Thanks for the help.&nbsp; Jon]]>
   <pubDate>Tue, 04 Apr 2023 07:06:17 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15640&amp;PID=151383#151383</guid>
   <title>TOILET VALVE :   Originally posted by jato Totally...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15640&amp;PID=151382#151382</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8960" rel="nofollow">gpokluda</a><br /><strong>Subject:</strong> 15640<br /><strong>Posted:</strong> 03 Apr 2023 at 8:09pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by jato</strong></em><br /><br />Totally agree with LA, remove the toilet off the flange, makes the task nearly 100% easier.&nbsp; Haven't had this issue but remember when I purchased the taller Thetford toilet 6 years ago, it was a simple task, the only extra thing needed was to purchase a sharkbite fitting and an additional 6" piece of pex tubing.&nbsp; Maybe the Thetford is more stout than the Dometic, no problem observed in 'flexing' or wimpiness when sitting on throne.<br></td></tr></table> +1&nbsp; Can't imagine replacing the valve with the toilet mounted to the floor. Take that sucker out, replace the valve, give&nbsp; the toilet a good cleaning and re-install. Then decide what you'll do with the rest of the day because you just spent less than 30 minutes doing all that.]]>
   <pubDate>Mon, 03 Apr 2023 20:09:25 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15640&amp;PID=151382#151382</guid>
   <title>TOILET VALVE : You should have received a manilla...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15640&amp;PID=151376#151376</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1146" rel="nofollow">jato</a><br /><strong>Subject:</strong> 15640<br /><strong>Posted:</strong> 02 Apr 2023 at 7:01pm<br /><br />You should have received a manilla envelope with your 190 and inside it will have various vendors and the paperwork/manuals who supplied/furnished the trailer.&nbsp; Mine included manuals/paperwork for the Suburban stove and HW heater, axle, Dometic fridge, Thetford toilet, water pump, brakes and&nbsp; converter.&nbsp; Special ordered ours w/o A/C, oven, or entertainments system, so of course no info was supplied for those items.<br>]]>
   <pubDate>Sun, 02 Apr 2023 19:01:27 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15640&amp;PID=151376#151376</guid>
   <title>TOILET VALVE : Does anyone know which model commode...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15640&amp;PID=151352#151352</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4761" rel="nofollow">Akula1</a><br /><strong>Subject:</strong> 15640<br /><strong>Posted:</strong> 30 Mar 2023 at 12:57pm<br /><br />Does anyone know which model commode I have in my 2019 RP190?]]>
   <pubDate>Thu, 30 Mar 2023 12:57:08 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15640&amp;PID=151352#151352</guid>
   <title>TOILET VALVE :  The Dometic tall toilet felt...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15640&amp;PID=151348#151348</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6036" rel="nofollow">lostagain</a><br /><strong>Subject:</strong> 15640<br /><strong>Posted:</strong> 28 Mar 2023 at 2:46pm<br /><br />The Dometic tall toilet felt like it was going to tip over and break. &nbsp;It creaked and made noises that sounded like plastic fracturing every time someone sat on it. &nbsp;The recalled version was not properly glued and leaked black water into the enclosed space, accumulating there to the olfactory delight of the users. &#091;<a href="https://thecampingadvisor.com/dometic-300-toilet-recall/" target="_blank">dometic-300-toilet-recall</a>&#093;&nbsp;The replacement was just as creaky and top heavy. &nbsp;<div><br></div><div>The ceramic toilet is much easier to clean and much more stable. &nbsp;It was a challenging installation because it needed more rear clearance vis-a-vi the center point of the drain, so I had to cut out part of the wall and inset the toilet. &nbsp;The advantage to doing that was that I was able to put foam around the part of the toilet at the very back where it went inside the wall space making a very solid installation. &nbsp;A little bit of seam tape that matched the back wall made the cut out virtually invisible. &nbsp;i'd post a picture but I don't know how.</div>]]>
   <pubDate>Tue, 28 Mar 2023 14:46:08 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15640&amp;PID=151348#151348</guid>
   <title>TOILET VALVE :  Totally agree with LA, remove...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15640&amp;PID=151346#151346</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1146" rel="nofollow">jato</a><br /><strong>Subject:</strong> 15640<br /><strong>Posted:</strong> 28 Mar 2023 at 7:17am<br /><br />Totally agree with LA, remove the toilet off the flange, makes the task nearly 100% easier.&nbsp; Haven't had this issue but remember when I purchased the taller Thetford toilet 6 years ago, it was a simple task, the only extra thing needed was to purchase a sharkbite fitting and an additional 6" piece of pex tubing.&nbsp; Maybe the Thetford is more stout than the Dometic, no problem observed in 'flexing' or wimpiness when sitting on throne.<br>]]>
   <pubDate>Tue, 28 Mar 2023 07:17:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15640&amp;PID=151346#151346</guid>
   <title>TOILET VALVE : It&amp;#039;s just a matter of disconnecting...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15640&amp;PID=151345#151345</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6036" rel="nofollow">lostagain</a><br /><strong>Subject:</strong> 15640<br /><strong>Posted:</strong> 28 Mar 2023 at 6:12am<br /><br />It's just a matter of disconnecting the hoses, then getting to the screws that hold the valve in place. &nbsp;Depending on how much space is available, and your abilities as a contortionists, it's a matter of being able to get to the screws that hold the valve in place with a screw driver. &nbsp;Mine happened to be especially tight for one of the screws and I ended up taking the toilet off the flange. &nbsp;That worked out well because I discovered that the flange had a crack in it and was in need of replacement. &nbsp;I put the valve in before remounting the toilet and it was super easy because the access is much better. &nbsp;It was the same process when I mounted the ceramic toilet. &nbsp;<div><br></div><div>The cracked flange issue, I believe, related to the fact that on that particular trailer they use a very tall Dometic toilet that feels a bit like the leaning tower of Pizza when you sit on it. &nbsp;I was lucky in that when I went to replace the valve, I found that there was also a recall on the toilet and received a new one from Dometic so waited to replace the valve until the new throne arrived. &nbsp;I had earlier looked at taking the valve out and realized that it was going to be a lot easier to take the toilet off, so I held off until the new toilet arrived. &nbsp;I believe the flange cracked because the leverage from the tall toilet was just too much for the plastic flange and it cracked at the attachment bolt holes. &nbsp;The ceramic toilet I mounted solved the leverage problem because it is only about 18" tall, but it is solid as a rock and will not exert any undue force on the flange.</div>]]>
   <pubDate>Tue, 28 Mar 2023 06:12:51 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15640&amp;PID=151345#151345</guid>
   <title>TOILET VALVE : Are they hard to fix? Any noteworthy...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15640&amp;PID=151344#151344</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1821" rel="nofollow">hogone</a><br /><strong>Subject:</strong> 15640<br /><strong>Posted:</strong> 28 Mar 2023 at 5:51am<br /><br />Are they hard to fix?&nbsp; Any noteworthy hints!!??&nbsp; Jon]]>
   <pubDate>Tue, 28 Mar 2023 05:51:48 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15640&amp;PID=151344#151344</guid>
   <title>TOILET VALVE : Supposedly the Beech Land valve...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15640&amp;PID=151342#151342</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6036" rel="nofollow">lostagain</a><br /><strong>Subject:</strong> 15640<br /><strong>Posted:</strong> 27 Mar 2023 at 5:41pm<br /><br />Supposedly the Beech Land valve is able to sustain some freezing that would damage a standard valve. &nbsp;On the other hand if you are sure to get all the water out, perhaps $10 price difference isn't worth it. &nbsp;I initially installed our Beech Land replacement valve in the stock Dometic plastic toilet, but later ended up getting a lower Dometic ceramic toilet and used it on the porcelain throne. &nbsp;I hope I never have to find out if it's really more freeze damage resistant than the OEM valve. &nbsp;It was a real bummer when it broke on a trip with no parts available. &nbsp;I kept the OEM valve as a spare, just in case. &nbsp;Either way you go, good luck in fixing it.]]>
   <pubDate>Mon, 27 Mar 2023 17:41:19 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15640&amp;PID=151342#151342</guid>
   <title>TOILET VALVE : Well that is a bummer Jon.Regardless,...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15640&amp;PID=151339#151339</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1146" rel="nofollow">jato</a><br /><strong>Subject:</strong> 15640<br /><strong>Posted:</strong> 27 Mar 2023 at 5:10pm<br /><br /><div>Well that is a bummer Jon.</div><div><br></div><div>Regardless, on eBay you can get the upgraded valve for Dometic pedal flush RV# 385311641&nbsp; models 300, 310, and 320 for $ 8.49 and that includes free shipping.&nbsp; <br></div>]]>
   <pubDate>Mon, 27 Mar 2023 17:10:50 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15640&amp;PID=151339#151339</guid>
   <title>TOILET VALVE : I got this one when the old Dometic...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15640&amp;PID=151338#151338</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6036" rel="nofollow">lostagain</a><br /><strong>Subject:</strong> 15640<br /><strong>Posted:</strong> 27 Mar 2023 at 2:53pm<br /><br />I got this one when the old Dometic valve cracked because of residual water. &nbsp;Two years later no problems and it works fine. &nbsp;<a href="https://www.amaz&#111;n.com/gp/product/B09P1WXMTW/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&amp;th=1" target="_blank">https://www.amazon.com/gp/product/B09P1WXMTW/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&amp;th=1</a>]]>
   <pubDate>Mon, 27 Mar 2023 14:53:58 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15640&amp;PID=151338#151338</guid>
   <title>TOILET VALVE : I dont think I got my toilet valve...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15640&amp;PID=151336#151336</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1821" rel="nofollow">hogone</a><br /><strong>Subject:</strong> 15640<br /><strong>Posted:</strong> 27 Mar 2023 at 9:42am<br /><br />I dont think I got my toilet valve blown out good!&nbsp; Which valve should I get?&nbsp; Many thanks, Jon]]>
   <pubDate>Mon, 27 Mar 2023 09:42:42 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15640&amp;PID=151336#151336</guid>
