water pump - Event Date: 07 Oct 2022 |
Page 123> |
hogone
Joined: 09 Apr 2013 Location: High Ridge, MO Online Status: Offline Posts: 1074 |
Calendar Event: water pumpPosted: 07 Oct 2022 at 11:54am |
Havent used my rpod all summer due to various circumstances. I dewinterized early spring and all was good. Plan on getting back in tune here real quick for the fall season, but decided to redrain everything so everything is fresh. Filled up tank, fired up the pump and it doesnt seem to be pressurizing. It runs, but no air or water coming out of faucets. Double checked all my valves, cleaned the screen (nothing really there), and double checked everything again. Thoughts, jpp
Jon & Pam
2025 GD 17MKE 2013 RP177(sold Nov 25) 2023 F150 2017 HD Streetglide CHEESEHEAD |
Joined: 14 Jan 2013 Location: Near Nashville Online Status: Offline Posts: 1456 |
Posted: 07 Oct 2022 at 2:20pm |
No water anywhere? Did you check the screen on the pump? If you have one, have you checked the valve on the antifreeze hose to make sure the pump isn't sucking air from that? I suppose you could have a clog on the water intake inside the tank. Not sure what you'd need to do about that. Maybe flush the tank a few times, using the tank drain on the bottom. Not the low point drains. I think it's a last resort, but you might have to unhook the intake hose at the pump and figure out a way to blow some air back into the tank from there. I'm sure there's check valve though, and I don't know where, TT
FJ Cruiser |
hogone
Posted: 07 Oct 2022 at 2:51pm |
nope, no water anywhere...bummer! Antifreeze hose valve is in correct direction. Screen pump was perfectly clean/clear. Will keep troubleshooting, thanks TT. jpp
Jon & Pam
gpokluda
Joined: 11 Nov 2018 Location: East Idaho Online Status: Offline Posts: 479 |
Posted: 07 Oct 2022 at 5:14pm |
How long did you let the pump run? I know on ours the hot water tank has to fill before we start seeing water. We get some cold but we don't see any consistent pressure until the entire system is charged. That usually takes a few minutes. Best of luck.
Gpokluda
2017 Rpod 179(sold 2023) 2022 Escape 5.0TA 2022 Ford F150 4X4 3.5EB Honda SCL500 |
hogone
Posted: 07 Oct 2022 at 5:29pm |
theres no pressure out of the pump; no air, no water spurts, nothing spurting out of faucets which should be happening as usual even when filling hot water tank to purge. gonna hook up direct water and power the lines. jpp
Jon & Pam
Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3425 |
Posted: 08 Oct 2022 at 5:51am |
Jon, Try opening the siphon hose (as if you were winterizing with antifreeze) with a jug of water and see if it will suck up water; sounds like you have an air lock somewhere preventing the pump from charging the system. I had that happen once, why I cannot explain but tried this and it worked.
hogone
Posted: 08 Oct 2022 at 6:34am |
jato: should I turn the bypass valves by the hot water tank as well like making believe Im winterizing? Or just hook up the siphon hose an go as is? jpp
Jon & Pam
Posted: 08 Oct 2022 at 1:30pm |
Just put the siphon hose in a jug of water you don't need to set the water heater bypass valves in winter mode. All you're trying to do is get the pump primed. For whatever reason it's not able to self prime by drawing water from the fwt. The siphon hose set in a jug of water will be above the level of the pump which will make it easier for it to prime itself.
Posted: 09 Oct 2022 at 2:50am |
Jon, hopefully your pump is now primed? Update?
hogone
Posted: 09 Oct 2022 at 10:42am |
nope, theres no suction from winterizing siphon hose!!!! this is a bummer. jpp
Jon & Pam
Page 123> |
