  <title>R-pod Owners Forum : water pump</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Podmods, Maintenance, Tips and Tricks : water pump</description>
  <pubDate>Wed, 28 Oct 2026 16:28:04 +0000</pubDate>
  <lastBuildDate>Fri, 28 Oct 2022 07:54:41 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=15485</WebWizForums:feedURL>
   <title>water pump :  I had a rattling sound in my...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15485&amp;PID=149927#149927</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 15485<br /><strong>Posted:</strong> 28 Oct 2022 at 7:54am<br /><br />I had a rattling sound in my pump a while ago. I disassembled it and found a washer inside one of the chambers. I think it had not been assembled correctly and the washer was pinched in the housing. After a few years, it had finally vibrated loose. After I disassembled it and reassembled it correctly, it has operated properly since.<div><br></div><div>As for the problem at hand, I think there is a check-valve in the pump. It may be stuck. I don't have a pump schematic to say for sure though.</div><div><br></div><div>Edit:&nbsp; I found this web site which may offer some help:</div><div><br></div><div><a href="https://www.loveyourrv.com/rv-water-pump-check-valve-functi&#111;n-and-replacement-how-to/" target="_blank">https://www.loveyourrv.com/rv-water-pump-check-valve-function-and-replacement-how-to/</a><br></div>]]>
   <pubDate>Fri, 28 Oct 2022 07:54:41 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15485&amp;PID=149927#149927</guid>
   <title>water pump : I realize I&amp;#039;m late to the...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15485&amp;PID=149924#149924</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4055" rel="nofollow">mikeyg2347</a><br /><strong>Subject:</strong> 15485<br /><strong>Posted:</strong> 27 Oct 2022 at 6:57pm<br /><br />I realize I'm late to the party, but....I had the same problem with my pump yesterday when I tried to get it to suck antifreeze into the system. It just wasn't happening. The day before it had been working perfectly. On a hunch I disconnected both hoses from the pump, turned the pump on and could feel it sucking air when I put my hand over the opening. Hooked it back up and it worked great. Maybe there was an airlock.]]>
   <pubDate>Thu, 27 Oct 2022 18:57:33 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15485&amp;PID=149924#149924</guid>
   <title>water pump : Never tried to see if it blows...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15485&amp;PID=149819#149819</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1146" rel="nofollow">jato</a><br /><strong>Subject:</strong> 15485<br /><strong>Posted:</strong> 15 Oct 2022 at 10:30am<br /><br />Never tried to see if it blows air when dry.&nbsp; I would simply yank the old one out and replace.&nbsp; If you want to check the new one, simply hook 12v to it and stick the incoming water line part of the pump in a bucket of water, careful you might get wet unless you point the outgoing line away from you.<br>]]>
   <pubDate>Sat, 15 Oct 2022 10:30:17 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15485&amp;PID=149819#149819</guid>
   <title>water pump : sorry, but have one more question...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15485&amp;PID=149818#149818</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1821" rel="nofollow">hogone</a><br /><strong>Subject:</strong> 15485<br /><strong>Posted:</strong> 15 Oct 2022 at 10:10am<br /><br />sorry, but have one more question before i yank this pump out.&nbsp; even though it may not be priming with water, should i at least get air blowing out the water lines?&nbsp; or is it one in the same?&nbsp; new pump has arrived!&nbsp; jpp]]>
   <pubDate>Sat, 15 Oct 2022 10:10:33 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15485&amp;PID=149818#149818</guid>
   <title>water pump : thanks jato, i just snagged!!!!...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15485&amp;PID=149785#149785</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1821" rel="nofollow">hogone</a><br /><strong>Subject:</strong> 15485<br /><strong>Posted:</strong> 11 Oct 2022 at 8:05am<br /><br />thanks jato, i just snagged!!!! jpp]]>
   <pubDate>Tue, 11 Oct 2022 08:05:21 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15485&amp;PID=149785#149785</guid>
   <title>water pump : Jon, I just checked on eBay for...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15485&amp;PID=149783#149783</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1146" rel="nofollow">jato</a><br /><strong>Subject:</strong> 15485<br /><strong>Posted:</strong> 11 Oct 2022 at 7:46am<br /><br />Jon, I just checked on eBay for a RV water pump, there is one that is 45 psi and 2.8 gpm for just over $ 38.00 with free shipping.<br>]]>
   <pubDate>Tue, 11 Oct 2022 07:46:07 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15485&amp;PID=149783#149783</guid>
   <title>water pump : maybe &amp;#034;Amazon&amp;#034;!! Would...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15485&amp;PID=149782#149782</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1821" rel="nofollow">hogone</a><br /><strong>Subject:</strong> 15485<br /><strong>Posted:</strong> 11 Oct 2022 at 7:04am<br /><br />maybe "Amazon"!!&nbsp; Would I need just the upper assembly, or the whole head (upper assembly, valve assembly, drive assembly).&nbsp; If the whole head, cheapest I can find is $80, which is more than the entire pump.&nbsp; Just trying to clarify.&nbsp; jpp]]>
   <pubDate>Tue, 11 Oct 2022 07:04:50 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15485&amp;PID=149782#149782</guid>
   <title>water pump : furpod....whats the &amp;#034;big...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15485&amp;PID=149781#149781</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1821" rel="nofollow">hogone</a><br /><strong>Subject:</strong> 15485<br /><strong>Posted:</strong> 11 Oct 2022 at 6:41am<br /><br />furpod....whats the "big a"?&nbsp;&nbsp;]]>
   <pubDate>Tue, 11 Oct 2022 06:41:51 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15485&amp;PID=149781#149781</guid>
   <title>water pump : Thanks for the follow up! As you...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15485&amp;PID=149774#149774</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9043" rel="nofollow">Dirt Sifter</a><br /><strong>Subject:</strong> 15485<br /><strong>Posted:</strong> 10 Oct 2022 at 2:22pm<br /><br />Thanks for the follow up! As you obviously realize, that helps us all.<br>]]>
   <pubDate>Mon, 10 Oct 2022 14:22:38 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15485&amp;PID=149774#149774</guid>
   <title>water pump : If the motor is spinning.. a new...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15485&amp;PID=149773#149773</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=936" rel="nofollow">furpod</a><br /><strong>Subject:</strong> 15485<br /><strong>Posted:</strong> 10 Oct 2022 at 2:17pm<br /><br />If the motor is spinning.. a new "head" can be had on the big A.. Like $17 last time I looked. 9 screws and it's changed, pay attention to screw length, they are not all the same.<br>]]>
   <pubDate>Mon, 10 Oct 2022 14:17:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15485&amp;PID=149773#149773</guid>
   <title>water pump : Yup, looks like I will yank the...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15485&amp;PID=149770#149770</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1821" rel="nofollow">hogone</a><br /><strong>Subject:</strong> 15485<br /><strong>Posted:</strong> 10 Oct 2022 at 5:59am<br /><br />Yup, looks like I will yank the pump.&nbsp; Just to clarify everything, I thoroughly winterized everything last fall with rv antifreeze as I have been for 10+ years.&nbsp; This spring dewinterized the entire system and everything worked wonderfully.&nbsp; A few days ago when I decided to drain everything just to rinse everything out (and I actually ran the pump prior to and it worked fine).&nbsp; When I say drain everthing, I mean fresh water tank, hot water heater, low point drains, etc.&nbsp; When I refilled fresh tank to fill hot water tank and fill lines, the pump would not prime as usual.&nbsp; Prob just a coincidence of the pump malfunction.&nbsp; Thanks all for your input.&nbsp; jpp]]>
   <pubDate>Mon, 10 Oct 2022 05:59:19 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15485&amp;PID=149770#149770</guid>
   <title>water pump : Even if you use air to winterize,...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15485&amp;PID=149763#149763</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 15485<br /><strong>Posted:</strong> 09 Oct 2022 at 7:39pm<br /><br />Even if you use air to winterize, it is good to run the pump for a little after draining the tank to empty any remaining water out of the pump if you are not going to be using the winterizing valve to pump RV antifreeze through the system.]]>
   <pubDate>Sun, 09 Oct 2022 19:39:49 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15485&amp;PID=149763#149763</guid>
   <title>water pump : Could have had a little water...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15485&amp;PID=149762#149762</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8600" rel="nofollow">offgrid</a><br /><strong>Subject:</strong> 15485<br /><strong>Posted:</strong> 09 Oct 2022 at 6:12pm<br /><br />Could have had a little water left in it which froze up last winter, since you havent been using it. Probably it's toast, but it wouldn't&nbsp; hurt to take the pump apart, clean everything up and inspect,<div>&nbsp;then if you like what you see put it back together and bench test it with a suction line and a water jug. . Sometimes you get lucky, and at worst you learn something for the next time someone has a problem.&nbsp;</div>]]>
   <pubDate>Sun, 09 Oct 2022 18:12:07 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15485&amp;PID=149762#149762</guid>
   <title>water pump : sorry if I mispoke. not at the...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15485&amp;PID=149760#149760</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1821" rel="nofollow">hogone</a><br /><strong>Subject:</strong> 15485<br /><strong>Posted:</strong> 09 Oct 2022 at 5:33pm<br /><br />sorry if I mispoke.&nbsp; not at the bowl, bit where the pump is bolted/screwed together in the mid section. will keep troubleshooting tomorrow.&nbsp; &nbsp;jpp&nbsp;]]>
   <pubDate>Sun, 09 Oct 2022 17:33:15 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15485&amp;PID=149760#149760</guid>
   <title>water pump : And, if needed, you can get a...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15485&amp;PID=149757#149757</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 15485<br /><strong>Posted:</strong> 09 Oct 2022 at 3:31pm<br /><br />And, if needed, you can get a complete filter for not much more than just the strainer bowl.<div><br></div><div><a href="https://www.amaz&#111;n.com/Strainer-Stainless-Replacement-Sediment-Compatible/dp/B08HZ33K9D" target="_blank">https://www.amazon.com/Strainer-Stainless-Replacement-Sediment-Compatible/dp/B08HZ33K9D</a><br></div>]]>
   <pubDate>Sun, 09 Oct 2022 15:31:18 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15485&amp;PID=149757#149757</guid>
   <title>water pump :   Originally posted by hogoneI...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15485&amp;PID=149756#149756</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1653" rel="nofollow">Tars Tarkas</a><br /><strong>Subject:</strong> 15485<br /><strong>Posted:</strong> 09 Oct 2022 at 2:41pm<br /><br /><div><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by hogone</strong></em><br /><br />I actually noticed that dirt sifter this morn.......not a crack but what semed to be a slight separation at seem (maybe thats what you mean)..........pump time......looks like 80 bucks.&nbsp; jpp</td></tr></table> <br></div><div>Not sure what you mean but if there is any air getting in due to a crack or a separation in/at the filter bowl, the pump is going to pump air, not water.&nbsp; New bowls are easy to find on Amazon.&nbsp; They come with a screen and a gasket.&nbsp; Real easy if that's what it is.</div><div><br></div><div>TT<br></div>]]>
   <pubDate>Sun, 09 Oct 2022 14:41:27 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15485&amp;PID=149756#149756</guid>
   <title>water pump : I actually noticed that dirt sifter...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15485&amp;PID=149755#149755</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1821" rel="nofollow">hogone</a><br /><strong>Subject:</strong> 15485<br /><strong>Posted:</strong> 09 Oct 2022 at 2:22pm<br /><br />I actually noticed that dirt sifter this morn.......not a crack but what semed to be a slight separation at seem (maybe thats what you mean)..........pump time......looks like 80 bucks.&nbsp; jpp]]>
   <pubDate>Sun, 09 Oct 2022 14:22:02 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15485&amp;PID=149755#149755</guid>
   <title>water pump : I had a small crack in the plastic...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15485&amp;PID=149754#149754</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9043" rel="nofollow">Dirt Sifter</a><br /><strong>Subject:</strong> 15485<br /><strong>Posted:</strong> 09 Oct 2022 at 12:53pm<br /><br />I had a small crack in the plastic crown on top of the pump that let air nix the suction. Replaced it and all worked well. Looking at the crack it looked more like a scratch. Good luck with your issue. <br>]]>
   <pubDate>Sun, 09 Oct 2022 12:53:25 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15485&amp;PID=149754#149754</guid>
   <title>water pump : Sounds like you may need a new...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15485&amp;PID=149752#149752</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6036" rel="nofollow">lostagain</a><br /><strong>Subject:</strong> 15485<br /><strong>Posted:</strong> 09 Oct 2022 at 12:24pm<br /><br />Sounds like you may need a new pump. &nbsp;I suppose you could take it out and test it just to be sure, but it looks like you have pretty much eliminated the other possibilities.]]>
   <pubDate>Sun, 09 Oct 2022 12:24:08 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15485&amp;PID=149752#149752</guid>
   <title>water pump : nope, theres no suction from winterizing...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15485&amp;PID=149749#149749</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1821" rel="nofollow">hogone</a><br /><strong>Subject:</strong> 15485<br /><strong>Posted:</strong> 09 Oct 2022 at 10:42am<br /><br />nope, theres no suction from winterizing siphon hose!!!!&nbsp; this is a bummer.&nbsp; jpp]]>
   <pubDate>Sun, 09 Oct 2022 10:42:36 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15485&amp;PID=149749#149749</guid>
   <title>water pump : Jon, hopefully your pump is now...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15485&amp;PID=149746#149746</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1146" rel="nofollow">jato</a><br /><strong>Subject:</strong> 15485<br /><strong>Posted:</strong> 09 Oct 2022 at 2:50am<br /><br />Jon, hopefully your pump is now primed?&nbsp; Update?<br>]]>
   <pubDate>Sun, 09 Oct 2022 02:50:21 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15485&amp;PID=149746#149746</guid>
   <title>water pump :   Just put the siphon hose in...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15485&amp;PID=149741#149741</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8600" rel="nofollow">offgrid</a><br /><strong>Subject:</strong> 15485<br /><strong>Posted:</strong> 08 Oct 2022 at 1:30pm<br /><br />Just put the siphon hose in a jug of water&nbsp; you don't need to set the water heater bypass valves in winter mode. All you're trying to do is get the pump primed. For whatever reason it's not able to self prime by drawing water from the fwt. The siphon hose set in a jug of water will be above the level of the pump which will make it easier for it to prime itself.&nbsp;]]>
   <pubDate>Sat, 08 Oct 2022 13:30:39 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15485&amp;PID=149741#149741</guid>
   <title>water pump : jato: should I turn the bypass...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15485&amp;PID=149734#149734</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1821" rel="nofollow">hogone</a><br /><strong>Subject:</strong> 15485<br /><strong>Posted:</strong> 08 Oct 2022 at 6:34am<br /><br />jato:&nbsp; should I turn the bypass valves by the hot water tank as well like making believe Im winterizing?&nbsp; Or just hook up the siphon hose an go as is?&nbsp; jpp]]>
   <pubDate>Sat, 08 Oct 2022 06:34:41 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15485&amp;PID=149734#149734</guid>
   <title>water pump : Jon, Try opening the siphon hose...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15485&amp;PID=149733#149733</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1146" rel="nofollow">jato</a><br /><strong>Subject:</strong> 15485<br /><strong>Posted:</strong> 08 Oct 2022 at 5:51am<br /><br />Jon,&nbsp; Try opening the siphon hose (as if you were winterizing with antifreeze) with a jug of water and see if it will suck up water; sounds like you have an air lock somewhere preventing the pump from charging the system.&nbsp; I had that happen once, why I cannot explain but tried this and it worked.&nbsp; <br>]]>
   <pubDate>Sat, 08 Oct 2022 05:51:06 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15485&amp;PID=149733#149733</guid>
   <title>water pump : theres no pressure out of the...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15485&amp;PID=149732#149732</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1821" rel="nofollow">hogone</a><br /><strong>Subject:</strong> 15485<br /><strong>Posted:</strong> 07 Oct 2022 at 5:29pm<br /><br />theres no pressure out of the pump;&nbsp; &nbsp;no air, no water spurts,&nbsp; nothing spurting out of faucets which should be happening as usual even when filling hot water tank to purge.&nbsp; &nbsp;gonna hook up direct water and power the lines.&nbsp; jpp]]>
   <pubDate>Fri, 07 Oct 2022 17:29:38 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15485&amp;PID=149732#149732</guid>
   <title>water pump : How long did you let the pump...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15485&amp;PID=149731#149731</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8960" rel="nofollow">gpokluda</a><br /><strong>Subject:</strong> 15485<br /><strong>Posted:</strong> 07 Oct 2022 at 5:14pm<br /><br />How long did you let the pump run? I know on ours the hot water tank has to fill before we start seeing water. We get some cold but we don't see any consistent pressure until the entire system is charged. That usually takes a few minutes. Best of luck.]]>
   <pubDate>Fri, 07 Oct 2022 17:14:25 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15485&amp;PID=149731#149731</guid>
   <title>water pump : nope, no water anywhere...bummer!...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15485&amp;PID=149730#149730</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1821" rel="nofollow">hogone</a><br /><strong>Subject:</strong> 15485<br /><strong>Posted:</strong> 07 Oct 2022 at 2:51pm<br /><br />nope, no water anywhere...bummer!&nbsp; Antifreeze hose valve is in correct direction.&nbsp; Screen pump was perfectly clean/clear.&nbsp; Will keep troubleshooting, thanks TT.&nbsp; jpp]]>
   <pubDate>Fri, 07 Oct 2022 14:51:48 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15485&amp;PID=149730#149730</guid>
   <title>water pump : No water anywhere? Did you check...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15485&amp;PID=149729#149729</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1653" rel="nofollow">Tars Tarkas</a><br /><strong>Subject:</strong> 15485<br /><strong>Posted:</strong> 07 Oct 2022 at 2:20pm<br /><br /><div>No water anywhere?&nbsp; Did you check the screen on the pump?&nbsp; If you have one, have you checked the valve on the antifreeze hose to make sure the pump isn't sucking air from that?</div><div><br></div><div>I suppose you could have a clog on the water intake inside the tank.&nbsp; Not sure what you'd need to do about that.&nbsp; Maybe flush the tank a few times, using the tank drain on the bottom.&nbsp; Not the low point drains.&nbsp; I think it's a last resort, but you might have to unhook the intake hose at the pump and figure out a way to blow some air back into the tank from there.&nbsp; I'm sure there's&nbsp; check valve though, and I don't know where,</div><div><br></div><div>TT<br></div>]]>
   <pubDate>Fri, 07 Oct 2022 14:20:24 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15485&amp;PID=149729#149729</guid>
   <title>water pump : Havent used my rpod all summer...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15485&amp;PID=149727#149727</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1821" rel="nofollow">hogone</a><br /><strong>Subject:</strong> 15485<br /><strong>Posted:</strong> 07 Oct 2022 at 11:54am<br /><br />Havent used my rpod all summer due to various circumstances.&nbsp; I dewinterized early spring and all was good.&nbsp; Plan on getting back in tune here real quick for the fall season, but decided to redrain everything so everything is fresh. Filled up tank, fired up the pump and it doesnt seem to be pressurizing.&nbsp; It runs, but no air or water coming out of faucets.&nbsp; Double checked all my valves, cleaned the screen (nothing really there), and double checked everything again.&nbsp; &nbsp;Thoughts,&nbsp; &nbsp;jpp]]>
   <pubDate>Fri, 07 Oct 2022 11:54:00 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15485&amp;PID=149727#149727</guid>
