  New Posts New Posts RSS Feed: Outriggers  Forest River parts
 Post Reply Post Reply Page  <1 910111213>
pedwards2932 View Drop Down
Post Options Post Options   Quote pedwards2932 Quote  Post ReplyReply Direct Link To This Post Topic: Outriggers Forest River parts
    Posted: 06 Oct 2021 at 4:52pm
NA
Post Options Post Options   Quote offgrid Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2021 at 7:03am
If it's dry you should be ok. If unsure get a wood moisture meter. Inexpensive and very handy tool to have around. You can also check water content in firewood, leaks around windows at home, etc.
moisture meter
Post Options Post Options   Quote pedwards2932 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2021 at 12:08pm
NA
Post Options Post Options   Quote offgrid Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2021 at 1:04pm
If they moved the frame out the floor would just sag worse in the center instead (there are plenty of cases of center sagging too).
They were trying to make the lightest cheapest floor possible and use a cantilever arrangement with overhangs on each side to make it work. Cantilevers are used all the time to extend the span of beams, and they generally work well.
The problem here is the thin lauan sandwich loses stiffness over time so while the cantilever design is sound in concept in practice it didn't work.
Post Options Post Options   Quote pedwards2932 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2021 at 1:22pm
Well I have ordered 4 more brackets.....probably only need 2 but I want some spares just in case i need them.  I agree with the floor sag in the middle but they could have added braces during construction and are doing so now.  I don't think the braces a strong enough for what they are trying to support but we will see.
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2021 at 1:25pm
I saw a new 179. The outriggers are now factory installed. That does not help those of us with older RPods, but it is good to know that FR recognized the problem and has actually done something to address it.
Pod People View Drop Down
Post Options Post Options   Quote Pod People Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2021 at 9:30pm
Stephen
did you notice where  FR located the outriggers?  How many are there? On both sides?
Any other info?
Thank you
Vann
Vann & Laura 2015 RPod 179
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2021 at 8:22am
Unfortunately, I did not take pictures. I think there were four. I only looked on the slide-side. They seemed to be evenly spaced. I did notice that they were welded to the frame and looked to have a rather sturdy bolt coming down through the end.
Post Options Post Options   Quote offgrid Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2021 at 8:38am
The braces are plenty strong enough. There is really very little weight on them, rpod walls are very light. The problem isn't that the loads are high it's that the floor is weak. Having to add the braces is a patch on the underlying (pun intended) problem. FR should put a stronger floor in rpods.
Post Options Post Options   Quote pedwards2932 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2021 at 9:01am
NA
