Water |
Sharon68
Joined: 03 Aug 2021 Location: Texas Online Status: Offline Posts: 4 |
Topic: WaterPosted: 09 Aug 2021 at 11:24am |
I have rpod 193 purchased March 2021
I STORED IT FROM JUNE 1 TO AUG 8 I TRANSPORTED FROM TEXAS TO MONTANA. I HAVE HOT AND COLD IN THE SHOWER AND TOILET WORKS I HAVE HOT WATER IN THE KITCHEN AND THE COLD BARELY STREAMS OUT. THE PUMP IS ENGAGING, I REMOVED THE AERATOR WHICH FIXED THE HOT WATER NOW WHAT I'm a travel nurse not a mechanic |
Ssmith
JR
Joined: 31 Aug 2018 Location: Manistee, MI Online Status: Offline Posts: 408 |
Posted: 09 Aug 2021 at 11:51am |
You might want to check the cold water feed line to the kitchen faucet for a blockage or blockage on the cold side of the faucet. Find an air compressor some where and use low air pressure to blow out the line. Low air pressure being under 40 psi. What would cause this is construction debris. Hope this helps.
Jay
179/2019 |
Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3436 |
Posted: 09 Aug 2021 at 3:10pm |
+1 Also check under your sink to see if your cold water line is kinked. Did the cold line ever function properly? Otherwise your line is either kinked or it came from the factory with debris in the line and as JR rightly states, a compressor will blow that out.
Leo B
Posted: 09 Aug 2021 at 4:01pm |
+2 sounds like a kinked line or it plugged!
pawpace
Joined: 06 Aug 2016 Location: KS Online Status: Offline Posts: 4 |
Posted: 29 Sep 2021 at 5:36pm |
I just had the same problem and the easiest fix is to unscrew the strainer off of the faucet, clean out the blockage in the strainer and reattach. Make sure you note how the parts are assembled.
Hope this fixes it, it did mine. Mike (getting ready to head out to Amana, Ia. for the R-Pod Octoberfest.)
Mike
