  New Posts New Posts RSS Feed: What size hitch ball ?
Topic ClosedWhat size hitch ball ?
jayber View Drop Down
Direct Link To This Post Topic: What size hitch ball ?
    Posted: 28 Mar 2011 at 4:50am
Seems like a dumb question but I cant seem to find what size hitch ball I need for my to be delivered r-pod. Are the different size balls interchangeable or do I need a specific size ball ?  Thanks for any help.
Jay
2010 Honda Odyssey
RP 171 aka PodInn
Direct Link To This Post Posted: 28 Mar 2011 at 7:09am
 A two inch hitch ball is needed. The question that is not asked is the one that is dumb. Happy to be of help. Congradulations on your new Rpod, hope you have many happy and safe years of enjoyment with it.     David and Danette
2014 Ram 1500 Quad cab
Direct Link To This Post Posted: 28 Mar 2011 at 9:32am
I also recommend getting a class III hitch.
Direct Link To This Post Posted: 28 Mar 2011 at 9:59am
The other question I had that I forgot to ask was, how high is the top of the receiver on the trailer, so I can figure out how much of a drop or rise I need.  I had a class III hitch installed this weekend along with a transmission cooler and power steering cooler.
Jay
2010 Honda Odyssey
RP 171 aka PodInn
Goose View Drop Down
Direct Link To This Post Posted: 28 Mar 2011 at 11:23am
  I had 14 inches from the ground to where the ball installs on the riser. I had to get a  2 inch riser/4inch drop for the Dodge Caravan that we had and we do not have a lift kit on our POD. That kept the POD level on the van. I had to use the riser side.  Just to make sure of where you are at, you could measure at the axle from the ground to the bottom of the frame and that should be where you need to be at the hitch.   Goose
Direct Link To This Post Posted: 28 Mar 2011 at 2:21pm
Its best if you can get the tounge of the 'pod to rest slightly downward if you can't get it level.  Don't let it sit at an upward angle, that will promote sway where a downward angle will help prevent sway.
