pedwards2932
Joined: 21 Sep 2020 Online Status: Offline Posts: 333 |
Topic: Highlander vs PathfinderPosted: 12 Apr 2021 at 2:42pm |
I am starting to look for a new (to me) TV. I like the Highlander and Pathfinder as they get similar gas mileage to my Escape but they have 5000 lb tow. I want to get one with the factory tow package and a couple of years old with lowest mileage I can afford. Anyone have either of these models? I have an RP189 dry weight is about 3225 so I am maxed out with my Escape and I don't want to have to worry about every little thing I want to load.
Posted: 12 Apr 2021 at 4:31pm |
I have a 2012 Highlander but I don't think the newer ones have significantly different ratings. It does fine with a wdh, but I do still have to watch my weights when boon docking, especially tongue weight. I can carry full fresh water, dual batteries, and a 2k genny,supplies for a week, a pop-up tent, a small grill and a reasonable tool set but that's about it. So it works. My 179 ends up at about 3700.
But If you really don't want to have to worry about it and you want to boondock and also carry some more heavy stuff like bikes or a kayak then I'd suggest going a size bigger. I think the Pathfinder is comparable to the Highlander but I'm not sure. Do get a dealership (not the one you're buying it at- ha ha) to confirm via the VIN that the vehicle has the factory tow package, it is prohibitively expensive on the Highlander to add some of that stuff aftermarket. |
AnnetteGary
Joined: 18 Mar 2021 Location: ON Online Status: Offline Posts: 22 |
Posted: 14 Apr 2021 at 9:44pm |
I'm trying to figure out how to post a question about a tow vehicle. We are trying to decide between a Toyota Tacoma or a Toyota Ridgeline. A used one to pull an R-pod 192. Any advice is much appreciated.
Thanks, Annette and Gary
Annettegary
Posted: 14 Apr 2021 at 9:50pm |
AnnetteGary
Posted: 14 Apr 2021 at 10:31pm |
Yes - you are correct of course. And between those three any recommendations?
thanks. Annette and Gary
Annettegary
Posted: 14 Apr 2021 at 10:56pm |
Annette and Gary, please compare the gross vehicle weight of the trailer and the towing capacity of the vehicles you are considering to see if they are within the limits of towing capacity. If you look in the archives, you will see lots of points of view, but the folks who have engineering experience all seem to recommend giving yourselves a reasonable margin of safety in staying somewhat below the TV's towing capacity. The trailer you are proposing has a gross vehicle weight of around 4800 lbs, so a towing capacity of 5000 lbs would not really give you much of a margin of safety. You may want something that can handle 6000 or 7000 lbs. in towing capacity.
If you check the archives, you can find OG's link to a towing capacity calculator which is very helpful in determining if the vehicle you tow with, or want to tow with, can safely handle the load.
Posted: 15 Apr 2021 at 8:17am |
I think the advice for a full-sized pickup is prudent. So, none of the above. Instead, look for a Ford F150, Chevy Silverado, Dodge Ram, Toyota Tundra, or Nissan Titan. Any one of those would be good. Personally, I am really liking the Ford F150 hybrid and would like to see one. That would eliminate the need to carry a separate generator.
poohbill
Joined: 22 Aug 2019 Location: Idaho Online Status: Offline Posts: 140 |
Posted: 31 May 2021 at 11:37am |
We tow 2016 189 with G2 Ridgeline just fine, without any mods. Very comfortable ride
