Outriggers Forest River parts |
Page <12345 13> |
JA-Pod
Joined: 28 May 2019 Location: Raleigh NC Online Status: Offline Posts: 35 |
Topic: Outriggers Forest River partsPosted: 29 Oct 2020 at 1:30pm |
My 2017 179 does not have a sag, just adding as a precaution since they are installed on later models, i too expect to have this pod for awhile. It is a cheap fix from FR, they cost $3.43 each + shipping.
John & Allison
R-Pod 179 (2017) Nissan Frontier SL V6 4.0 (2019) |
Posted: 29 Oct 2020 at 4:02pm |
I would add them as a precaution. Mine was starting to have a visible sag.
Posted: 29 Oct 2020 at 4:21pm |
Y'all have convinced me, and the price is right. I think I'll order them. Is 4 the recommendation from FR?
JA-Pod
Posted: 29 Oct 2020 at 4:27pm |
When I ordered them that is what FR recommended. Also from my point of view each support should go directly under the slide roller there are 4 of them.
John & Allison
Posted: 29 Oct 2020 at 5:16pm |
OK thanks. I'll take a look and see. I want to keep the brackets away from the axle attachments to avoid compromising the frame, which is also pretty marginal structurally.
Pod People
Joined: 22 Sep 2011 Location: Chapel Hill,NC Online Status: Offline Posts: 1098 |
Posted: 29 Oct 2020 at 6:02pm |
thanks for the info-I guess I need to get some also Vann
Pod People
Posted: 02 Nov 2020 at 2:53pm |
I just spoke with Amanda in the parts department (574-642-3119x4) and ordered 4 outriggers. For the record, the part number is F100140948 which is 1 outrigger and the complete screws/bolts for installation. They cost $3.43 each plus shipping. Thanks for all of the previous info. I'll post a picture when I get them installed. Vann
JA-Pod
Posted: 15 Nov 2020 at 2:27pm |
I was able to install the 4 outriggers which I installed mostly under the rollers of the slide out. I had to carve away some of the aluminum channel using an Oscillating Multi tool so I could slip the end of the outrigger onto the channel, I considered sliding it under the channel but could not pry it up since it is very much integrated into the floor and wall, did not want to compromise the integrity of the floor/wall connection. I did add a backer plate which was suggested and added galvanized bolts, locking washers and nuts. I did not use the FR solution of long screws. I added caulk to the screw heads and will touch up with black paint. All in all I feel good about the outcome of the supports.
John & Allison
Posted: 15 Nov 2020 at 4:51pm |
Looks good. Did you consider letting the Al channel rest on the outrigger rather than removing it? Just wondering if that would have worked?
Posted: 15 Nov 2020 at 6:01pm |
Setting on the channel would have left a gap between it and the floor of the slide-out. I cut my homemade outriggers so they would just fit to the inside of the channel. Instead of cutting the channel, the alternative would have been to put a shim between the floor and the outrigger. I would like to see how the factory installs them. Does anyone have a picture of a factory installed outrigger for reference?
Page <12345 13> |
