  New Posts New Posts RSS Feed: A couple of questions
Topic ClosedA couple of questions
Direct Link To This Post Topic: A couple of questions
    Posted: 02 Aug 2020 at 11:32am
SH,
I used the CAMCO 59123, comes with hoses, to add ability to attach grill, or fireplace, also add additional tank temporarily.
Direct Link To This Post Posted: 02 Aug 2020 at 11:45am
Offgrid,
+1, Mine does too. I have a 30A RV connector so I use it. When I put the Pod in building I don't have access to my RV connector, so I run it off the wall, a 20A circuit.
Direct Link To This Post Posted: 02 Aug 2020 at 3:29pm
Originally posted by mcarter
SH,
Thanks. I looked at it and it looks like it likely would not work for my situation. I already did a dual-tank setup on the tongue with auto-switchover. This looks like it is more for a large tank that fills in place on a motor home. I'm looking more for a low-pressure fitting but would need to find a manifold with an empty spot to attach a hose to give me the equivalent of what the newer RPods have.
Direct Link To This Post Posted: 02 Aug 2020 at 4:05pm
Hey S/H, understand. I didn't want to do a dual tank conversion. I have plenty of space to carry a spare tank. My tongue weight is at 382, didn't want to go higher. Also I didn't want a low pressure grill, it's to single purpose. Also I wanted option to use other accessories to include grill. The coupler allows all that and is a 3 min install on existing tank.
Pod_Geek View Drop Down
Direct Link To This Post Posted: 02 Aug 2020 at 6:22pm
Originally posted by podwerkz
...BTW that LP port on the frame is almost worthless. Forget it is there. Seriously....
Ouch
Our 195 has that port in conjunction with the outdoor stove (which slides out from the pass-through) and it works great (and is very handy).
2020.5 R-Pod 195 Hood River
2018 RAM 2500 6.4L
podwerkz View Drop Down
Direct Link To This Post Posted: 02 Aug 2020 at 6:49pm
If your r-pod came with an outdoor stove that connects to that port, that's a fine use for it.
But the r-pods without the optional outdoor stove that come with that port mounted on the frame, by itself, well, thats a lot less useful without buying a dedicated appliance and connector or two. Much simpler to just buy an off-the-shelf camping stove and use that...or so it seems to me.
Again, just my opinion.
Direct Link To This Post Posted: 02 Aug 2020 at 8:00pm
I can agree with that.  Just want to make sure that the poster knows that the auxiliary LP port is not a complete waste.
We actually use both...the stove and the ever-ubiquitous baby Weber grill with its own tank of propane. Can sautée onions and peppers while grilling brats Big smile
2018 RAM 2500 6.4L
Badweissenbier View Drop Down
Direct Link To This Post Posted: 02 Aug 2020 at 8:36pm
FYI there is an adaptor for the low pressure supply for black stone grills. It does away with the regulator.
Mirado View Drop Down
Direct Link To This Post Posted: 03 Aug 2020 at 1:40pm
My 2015 has a low pressure propane port under the rear bumper (garage model) and came with a grill.  We don't use the grill, but have a Blackstone griddle.  The small canisters don't last long with the Blackstone, so I got an adapter hose and run the griddle directly from the LP port.
Miriam and Doug
2015 Rpod 181G
Silverado 1500
Direct Link To This Post Posted: 03 Aug 2020 at 3:41pm
Yummy! I can smell that from here!
Thumbs Up
